Thinking of getting the cruise control working. Where do I start? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-08-2012, 03:27 PM Thread Starter
gregp1962's Avatar
Date registered: Nov 2006
Vehicle: 1984 300CD
1984 300CD
I realize that cruise control rarely works on these. Mine is no exception. Since it hasn't worked in the year that I have had the car, I don't even know where to start. What should I check first? Are there any good write ups on how these even work?
1984 300CD
gregp1962 is offline
post #2 of 9 (permalink) Old 12-08-2012, 03:39 PM
R.P. McMurphy's Avatar
Date registered: Dec 2010
Vehicle: 1984 300dt 1985 300 dt 1992 300e just added another 92 300e 1994 e420 1993 300te 4matic
Quoted: 272 Post(s)
R.P. McMurphy is offline
post #3 of 9 (permalink) Old 12-09-2012, 09:35 AM
Date registered: Sep 2011
Vehicle: 1982 300D Turbo
Originally Posted by gregp1962 View Post
1984 300CD
I had my cruise amp replaced earlier this year. the cruise will engage, but it won't accelerate on a hill, and won't really hold the speed. I'd save your money/time for another repair. I'm about to take mine out...
Stephen
1982 300D Turbo
1975 Cadillac sedan deVille
shwhitley is offline
post #4 of 9 (permalink) Old 12-09-2012, 09:52 AM
Quoted: 272 Post(s)
...a lot of people have been successful by removing the amp under the dash (?) an re soldering the connections. the solder they used cracked over time. i think its non reson soldier you want but youd have to check to be sure.
post #5 of 9 (permalink) Old 12-09-2012, 11:09 AM
codepony's Avatar
Date registered: Oct 2012
Vehicle: 1979 240D
Quoted: 33 Post(s)
My cruise control is broken and since I only use it on very long drives, maybe once a year or so, I just disconnected it and plan on removing it at some point.
codepony is offline
post #6 of 9 (permalink) Old 12-09-2012, 03:13 PM
Vehicle: 1985 300D Turbo-diesel
I too would like to get mine working and have searched but too no success...although my cruise control does work if you count heavy acceleration as working, works great for fast passes-55 to 80 in like 1 sec, deceleration only seems to work if you hold it, then its back to heavy acceleration
Any thoughts?
1985 Black w/sunroof 300D Turbo-Diesel
black85benz is offline
post #7 of 9 (permalink) Old 12-10-2012, 08:26 AM
Vehicle: 1978 350SL, 1984 300CD 2003 SLK32 AMG
Quoted: 4 Post(s)
I have a 1984 300CD as well. I have repaired the cruise on mine. There are four main components to the system with wire in-between them all.
1. Amplifier
2. Servo motor
3. Control switch
4. Speed signal generator
I first checked the servo motor, which pulls on the throttle linkage, as best that I could. The electric motor ran well and the feedback wiper was in good shape and the gear train was in good shape so I figured it as OK. I then checked all the functions of the Control switch electrically and it was good. Next, I checked the speed signal generator which looked OK. That left the amplifier as the most probable culprit. I decided to purchase a remanufactured unit, done by Programma. I my case the amp was the problem! I used an electrical multi-meter and troubleshooting information from a website GDL-online.com: Test Procedures - Table of Contents. They offer troubleshooting documents and remanufactured servos and amps along with many other products. If you are not comfortable using a multi-meter and working on electro-mechanical devices a DIY repair may not be the best choice! I would guess that the amp is the most common point of failure.
jaybutter is offline
post #8 of 9 (permalink) Old 12-10-2012, 06:02 PM
Date registered: Dec 2006
Vehicle: 1985 300D California / 2006 E350
+1
Everything looked OK on mine, but it didn't work at all. I got a rebuilt amplifier from Ebay 4 years ago, and it's been working perfect ever since.
2006 E350
theo3000 is offline
post #9 of 9 (permalink) Old 12-10-2012, 07:14 PM
Date registered: Jan 2011
Vehicle: 2014 Mercedes-Benz GLK250 Bluetec, 1981 Mercedes-Benz 300D W123
Quoted: 11 Post(s)
sethwm2 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
