Heater Blower Issue '78 300D - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-28-2012, 01:25 PM   #1 (permalink)
Date registered: Nov 2012
Vehicle: 1978 300D / 1987 300SDL / 1981 240D
Hello! Let me say that I have learned more from these boards that I could ever imagine.
My daily driver, 78 300D just developed a fairly weird issue: The Lo and Hi fan speeds stopped working. Note: the defrost mode works well, fan blows hard and hot. I am very versed in this car, I have had few electrical problems and few vacuum problems, but obviously, I have a problem now!
I'm going to tear into it this evening and start looking for the issue and I'm sure I'll track it down, but anything in particular that I should be looking for first?
Thanks in advance! Erik
bscrecords is offline   Reply With Quote
Old 11-28-2012, 02:33 PM   #2 (permalink)
Date registered: Dec 2010
Vehicle: 77 240D
no schematic at hand, but i think there is a resistor pack in that circuit which could potentially blow out. i would find it, disconnect one side, and test with an ohmmeter.
bricktron is offline   Reply With Quote
Old 11-28-2012, 02:58 PM   #3 (permalink)
Thanks. I'll find it.
Old 11-28-2012, 06:04 PM   #4 (permalink)
My 300d has the exact same problem. Please let me know if you find a fix!
Bobbywheels1212 is offline   Reply With Quote
Old 11-28-2012, 07:34 PM   #5 (permalink)
I will update. Got the control unit out, but then a friend stopped by and reminded me how cold it was outside.
Old 11-28-2012, 08:45 PM   #6 (permalink)
Date registered: Jan 2012
Vehicle: 1979 300D
Often the "only defrost" problem is related to issues with the climate control servo. Can't say for sure. However, the defrost only is basically the fail safe literally for safety's sake when the servo fails to work in any other mode.
Do some searching on here and over on peachparts.com and you'll find lots of info on doing diagnostics.
1979 300D auto Black on Black MB-Tex
2001 BMW 540i M-sport 6spd Silver
1963 Plymouth Savoy slant-6 3-speed Hurst "rat rod"
1963 Schwinn Corvette single speed for when all the above aren't working!
uberwasser is offline   Reply With Quote
Old 11-30-2012, 08:33 AM   #7 (permalink)
Well, it was not the dreaded servo. Alas, I had corroded contacts. That climate control unit is a bear to break down.
Bookmarks
