Please help! Photo or diagram request for engine vacuum lines ('79 300D) - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 04-08-2012, 10:53 AM Thread Starter
Date registered: Apr 2012
Exclamation Please help! Photo or diagram request for engine vacuum lines ('79 300D)
I got a 1979 300d for $1000, its really nice. The only problem is that the vacuum lines are all unplugged and some are missing. Ill post pictures of the madness. I recently ordered a main brake vacuum line with the two T's, the one this 300d has are both broken. Here are picture of what its like now. I was wondering if anyone can post pictures of how there vacuum lines are plugged in? That way I just copy how yours are. It should be easy if anyone could help i'd really appreciate it. Thank You
ID:	436649   Click image for larger version
ID:	436650   Click image for larger version
ID:	436651   Click image for larger version
ID:	436652   Click image for larger version
wolfraw is offline
post #2 of 15 (permalink) Old 04-08-2012, 11:58 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
The link may help.
Mercedes Engine Vacuum
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
post #3 of 15 (permalink) Old 04-08-2012, 03:15 PM Thread Starter
Thank you, i'd really appreciate some kind of photo or diagram with color coded vacuum lines. That link wasn't very helpful. But thank you
wolfraw is offline
post #4 of 15 (permalink) Old 04-08-2012, 03:16 PM Thread Starter
Because as you can see in my picture all the lines are incorrect or missing lines.
wolfraw is offline
post #5 of 15 (permalink) Old 04-08-2012, 08:02 PM
Rmac58's Avatar
Quoted: 139 Post(s)
79's are different from what I have, but perhaps some items are the same.
Brown/violet is going to the shut off actuator.
Brown is going to the ignition switch.
Yellow & yellow/red is for the door lock system.
Green/yellow is climate control.
Not sure about the red line, in Euro's that's for the headlight adjustment.
'84 CD-weekender!
Rmac58 is offline
post #6 of 15 (permalink) Old 04-08-2012, 08:51 PM
archham's Avatar
Date registered: Dec 2009
Vehicle: 1979 300D - 105K miles
Quoted: 8 Post(s)
I have a 1979 300D. Will try to get you some pics tomorrow.
Sent from my Autoguide iPad app
1979 300D - 105k
1972 220D- sold
1969 220D - sold
archham is offline
post #7 of 15 (permalink) Old 04-08-2012, 10:30 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Check this thread. Very informative and may just help you: http://www.benzworld.org/forums/w123...get-right.html
benzmizer is offline
post #8 of 15 (permalink) Old 04-08-2012, 11:30 PM Thread Starter
Thank you Rmac58 Will see if it does the job! I just need to get the brake vacuum hose with the two T's to connect everything. I really appreciate it
wolfraw is offline
post #9 of 15 (permalink) Old 04-08-2012, 11:33 PM Thread Starter
archham that would be a major help! I would also appreciate it! I have instructions and a photo will help even more
wolfraw is offline
post #10 of 15 (permalink) Old 04-08-2012, 11:40 PM Thread Starter
benzmizer thank you, but my 1979 300d vacuum lines are alot more simple, thats why I'd like a picture of what a 1979 300d engine should look like. But thank you for taking time to help me
wolfraw is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Photo request: SBU brake lines Korpisoturi Unimog 1 10-25-2010 04:22 AM
    vacuum lines diagram benzito84 W202 C-Class 10 04-02-2009 05:11 PM
    can someone take a digital photo of vacuum lines 82-300d flukinfool W123 E,CE,D,CD,TD,TE Class 8 02-15-2009 07:22 AM
    Vacuum Lines-- anyone have the diagram? jdjones2001 W201 190-Class 4 06-11-2008 11:47 AM
    M116 engine vacuum lines diagram needed! marek W126 S,SE,SEC,SEL,SD,SDL Class 2 04-06-2005 03:04 AM
