85 300cd alternator adjustment bolt...how to replace? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-23-2012, 08:59 AM Thread Starter
Date registered: Feb 2007
I snapped the bolt and got a new one from the dealer. It seems the only way to get the old nut out is to bend the bracket that is holding it so it can slide out of the slot. Is that right?
benztech123 is offline
post #2 of 14 (permalink) Old 03-23-2012, 12:52 PM
Stretch's Avatar
Date registered: Jul 2011
Vehicle: 1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
Quoted: 521 Post(s)
Here are some pictures of the alternator adjusting bracket...
Taken from here
PeachPartsWiki: Refreshing the Alternator
Which bit did you bust?
1992 190E 1.8 <=>2.0 201.018 => Daily driver
1981 300D (non turbo) 123.130 => Project car - stripped to the bone
1965 Land Rover Series 2a Station Wagon => CIS recovery therapy!
Free and legal FSM download => Ask for help if you get stuck!
Don't leave that there I'll take it to bits
Stretch is offline
post #3 of 14 (permalink) Old 03-24-2012, 08:47 AM Thread Starter
i broke the 90 degree bolt, the one with one end that goes to the adjustment nut and the other end goes through the alternator bracket. (the one in the left hand of the guy in the last pic you posted.)
post #4 of 14 (permalink) Old 03-24-2012, 09:51 AM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
It has been a long time since I messed with the Alternator but you to bend the bracket some but before you do that remove the Belts from the Alternator Pulley so you can pivot the Alternator around more.
There is cheaper places to buy the Alternator Bolt. Also there is a much cheaper Fix to replace that bolt.
You stick a slighly longer regular Bolt through and Eye Bolt and use a Nylock type Locking Nut on the Threaded protion of the Eye Bolt to replace the regular adjusting Nut (not needed if you can find a Metric Eye Bolt that matches the threads of the stoc Alternator adjustin Nut).
I will search my notes to see if I have another thread or picture.
300Dman is offline
post #5 of 14 (permalink) Old 03-24-2012, 09:53 AM
Vehicle: 1984 300D
Quoted: 73 Post(s)
This might be the thread
Using an Eye Bolt to repair a broken alternator tensioner bolt
Stuck on V-Belts: ALternator bolts frozen and tension bolt broken - Page 2 - PeachParts Mercedes ShopForum
This thread has how to remove the Altenator Bolt so doing the opposite must allow you to install the Alternator Bolt.
http://www.benzworld.org/forums/w123...ator-hell.html
300Dman is offline
post #6 of 14 (permalink) Old 03-24-2012, 10:53 AM Thread Starter
Okay, thanks for the links. The eye bolt fix looks slick, but even to do that I still have to get the old adjuster nut off the bracket. This is a rediculos design. How in the hell did they get nut in there in the first place? Put it in and bend the bracket to old it? Seems very labor intensive...
post #7 of 14 (permalink) Old 03-24-2012, 10:58 AM Thread Starter
fortunately i have the radiator, fan, shroud, and all the belts off anyway so i have plenty of room to get my hands in there. i have another thread going but this started because my crank pulled bolts snapped off in the balancer. i got that squared away and snapped this damn bolt during reassembly. its the little things....
post #8 of 14 (permalink) Old 03-24-2012, 12:36 PM
Vehicle: 1984 300D
Quoted: 73 Post(s)
There is 2 things that commonly break them; the Adjustment Nut being rusted to the threads; the next is not loosening the Nut on the Large Bolt before you start Turning the Adjustment Nut.
A Never Seeze type compound on the Threads helps keep it from Rusting.
Old Benzes really like attention!
300Dman is offline
post #9 of 14 (permalink) Old 03-24-2012, 12:41 PM
Vehicle: 1984 300D
Quoted: 73 Post(s)
The Mercedes Engineers clearly have different ideas than the other Car Makers; with mixed results.
I think Mercedes believed for the whole life of the Car it was going to be taken care of by Mercedes Trained Mechanics.
300Dman is offline
post #10 of 14 (permalink) Old 03-24-2012, 08:27 PM Thread Starter
trained to bend things out of the way?
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    300CD Alternator Power dieselbenzfan123 W123 E,CE,D,CD,TD,TE Class 2 04-23-2008 11:50 AM
    alternator adjustment bolt backed out all the way rdyson W123 E,CE,D,CD,TD,TE Class 0 01-02-2008 08:10 AM
    300CD 1978 alternator help ! akimball442 W123 E,CE,D,CD,TD,TE Class 16 12-04-2007 07:51 PM
    alternator adjustment bolt jjovero25 W123 E,CE,D,CD,TD,TE Class 0 04-29-2007 09:16 AM
    Alternator Bolt Servord W126 S,SE,SEC,SEL,SD,SDL Class 2 01-26-2005 01:35 PM
