85 300D Turbo Suspension Parts Diagram - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-19-2012, 06:14 AM Thread Starter
Date registered: Mar 2012
Vehicle: 1985 MBZ 300D Turbo
Hi All - had a minor mishap in the rain where a curb was hit with the left front. Obviously something is bent as there is now negative camber and the whole wheel assembly is pushed rearwards. I took off the wheel and can see a bent rod that attaches underneath where the shock attaches to the suspension piece. Thing is - I know what I see but not what the bits are called so I'm hoping to find a parts diagram so I can ID what I need to order! Any pointers?
Thanks!
dudecati is offline
post #2 of 7 (permalink) Old 03-19-2012, 07:09 AM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 343 Post(s)
Here's a pointer
ID:	433067   Click image for larger version
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #3 of 7 (permalink) Old 03-19-2012, 08:33 AM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
Sounds like you are speaking of part #100 in the lower pic. One of the Names for that part is the Strut Rod, Guide Rod and Track Rod.
Mercedes part number 1233302130.
An online genuine Mercedes parts wants $45 for that part. Aftermarket parts seem to be around $30.
Pulling one at the Junk Yard may only cost you several dollars and you would get a real Mercedes one.
You also want to take a really good look at where the Heavy cast Lower control Arm mounts on the Frame and see if the sheet Metal parts where it pivots is also bent.
300Dman is offline
post #4 of 7 (permalink) Old 03-19-2012, 09:08 AM Thread Starter
Thanks all - both the pic and the advice help a lot! I noticed that the cup that holds the spring in place is twisted too so that needs replacing.
I'll look for the mounts on the frame too. Is that a replaceable part or if it is bent am I in for a more serious issue?
dudecati is offline
post #5 of 7 (permalink) Old 03-19-2012, 10:24 AM
Stretch's Avatar
Date registered: Jul 2011
Vehicle: 1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
Quoted: 523 Post(s)
If you are talking about the part of the chassis that part 75 (second picture) fits to, then you've got a bit of a problem. If that is done in you'll have fun and games getting the front suspension right again. If that is the case post up some pictures - we might be able to suggest some remedies.
Because you've hit the front so hard and managed to bend part 100 (second picture) you need to check out the anti-roll bar mounts at that are on the bulkhead behind the engine too. I can imagine that by bending that bar (100) you could end up with trouble higher up. The anti roll bar is attached to parts 210, 206, 203, 199 etc in the first picture.
1992 190E 1.8 <=>2.0 201.018 => Daily driver
1981 300D (non turbo) 123.130 => Project car - stripped to the bone
1965 Land Rover Series 2a Station Wagon => CIS recovery therapy!
Free and legal FSM download => Ask for help if you get stuck!
Don't leave that there I'll take it to bits
Stretch is offline
post #6 of 7 (permalink) Old 03-26-2012, 08:33 AM Thread Starter
SInce you are so good that the name that part and PN game, can you help me id #'s 125, 128 & 140 in diagram #2? I'm finally getting around to making a parts order and I can't find the names or PNs for those items.
Thanks!
dudecati is offline
post #7 of 7 (permalink) Old 03-26-2012, 09:20 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
#125 is referred to as a spring case.
The attachment may help with the other items.
Please put your car in your avatar or sig, fill out your location too maybe.
File Type: jpg Screen shot 2012-03-26 at 12.17.29 PM.jpg (21.9 KB, 381 views)
File Type: jpg Screen shot 2012-03-26 at 12.19.35 PM.jpg (22.3 KB, 413 views)
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Anyone interested in parts for 1982 300d turbo? flukinfool W123 E,CE,D,CD,TD,TE Class 5 08-16-2009 11:59 AM
    300D Turbo -- Parts Car? tusker23 W123 E,CE,D,CD,TD,TE Class 6 11-26-2008 05:34 AM
    1984 Mercedes 300D Turbo Diesel PARTS xtreasurehunter For Sale/Wanted/Trade/Giveaway 1 12-16-2007 09:57 AM
    1983 300D Turbo Diesel Parts FS Ed83 For Sale/Wanted/Trade/Giveaway 0 07-06-2005 04:48 PM
    vacuum diagram for 300d turbo rey445588 W123 E,CE,D,CD,TD,TE Class 0 08-18-2002 09:07 AM
