Rear axle bearings - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-26-2012, 03:36 PM Thread Starter
Date registered: Oct 2011
Rear axle bearings
I have a slight bit of play on both rear wheels . I was thinking of retorquing the bearings as a means to remove the end play........anyone have any thoughts on this?"..........tks.......Vince
vince007 is offline
post #2 of 5 (permalink) Old 01-26-2012, 08:44 PM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
The end play on the Rear Wheels is adjusted differently than you would think; there is no Torque spec on the Retaining nut.
There is a Spacer/Collar inside between the Inner Bearing and the Hub that is designed to be crushed.
You tighten the Inner Nut with the special Pin Wrench while checking the end Play on the Hub with a Dial Indicator.
Once the End Play is obtained the locking washer is crimped into some of the spaces on the Locking Nut.
If you tighten it up too much you have to take it apart again and sart over with a new Sleeve/Collar; because the original has already been crushed too much.
The problem with taking the Rear Wheel Hub off again to change the Sleeve/Collar is that the Bearing get damaged as the Manual calls for the use of a Slide Hammer to remove the Hub.
Owners have found that you can attach an Old Brake Rotor Backwards on the Rear Hub and use that to beat on with a Hammer instead of using a Slide Hammer.
I would do some searching for a more detailed description of the Job.
Repair Links
DIY Links by Parts Category - PeachParts Mercedes ShopForum
PeachPartsWiki: Do It Yourself Articles - Mercedes Vehicles
Becareful about damaging the Rear Hub as they are over $300 new and as you will see not so easy to remove at the Junk Yard. The inner part where the Treads are is rather thin and if you beat on it it can bend.
300Dman is offline
post #3 of 5 (permalink) Old 01-27-2012, 02:46 AM Thread Starter
Repair Links
thanks I'll watch for your suggestions when i attempt this tomorrow, My experience with taper roller bearings is zero end play is desirable. The crush sleeve appears to be a device that makes up for assemble dim controls from the factory. An easy way to facilitate sizing when stacking many parts together. So if I were to continue to crush the sleeve ( in theory) I would be taking up slack that has resulted from normal wear on the bearing. Hopefully I'm on the right track.......tks ....Vince
vince007 is offline
post #4 of 5 (permalink) Old 01-27-2012, 06:59 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
One of my new rear bearings loosened a little after installation and I did what you are going to do. Be very careful tightening the play. Take it 1/16 turn at a time and recheck. It doesn't take much to overtighten the crush sleeve.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #5 of 5 (permalink) Old 01-27-2012, 07:47 AM
Vehicle: 1984 300D
Quoted: 73 Post(s)
The Rear Spacing Sleeve I drew in Red.
The set end play is 0.04-0.06mm
If Shims had been used instead of the Crush type Spacing Sleeve a person would have to some how pull out the inner Bearing (without damaging it) each time the Shims needed to be changed.
Or, Mercedes would have used a different locking Nut system.
What I do not like about the system (besides a lot of work and the need for a special tool) is that Beating the Hub out damages the Bearing/s.
I managed to crack one of my Trailing Arms (I ran over a 3" high Traffiic Island at about 45 mph); it had some rusth holes in it.
I changed the whole Rear Trailing Arm with a used one.
Later I aquired the Special Tool to turn the Nut and I also found out how much the a New Rear Hub costs and decided to salvage the Hub and keep it.
I used the reversed old Brake Rotor and beat on it method. It took considerable beating to get the Hub out. So I can see how that damages the Bearings.
Name:	Rear Axle Spacing Sleeve.jpg
300Dman is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Axle, bearings, or what?? ChuangTzu W123 E,CE,D,CD,TD,TE Class 16 02-11-2009 06:26 AM
    FRONT AXLE WHEEL BEARINGS sak384 W210 E-Class 1 07-19-2007 09:14 PM
    Rear Axle Bearing Rotating in Axle-Housing fernweh G-Class 11 12-19-2005 11:59 AM
    Rear axle pinions seals and bearings petermerle G-Class 7 06-10-2004 05:12 AM
    FNT AXLE bearings problems Which is better? Irish sean G-Class 7 07-15-2003 03:39 PM
