W123 Cell Phone Chargers and Cigarette Lighters - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-07-2011, 09:32 AM Thread Starter
Date registered: Jan 2011
Vehicle: 2014 Mercedes-Benz GLK250 Bluetec, 1981 Mercedes-Benz 300D W123
Quoted: 11 Post(s)
When I first got my 81' 300D last winter, the cigarette lighter would make my phone charger light up if I wiggled it around just to the right spot.. it seems as though it is a lot deeper and wider than modern cigarette lighter ports and not one car charger that I tried it in would fit and or stay in the port without falling out. Then it would not even charge if I held it (I'm guessing I blew a fuse)
What does everyone else do to charge their phones whilst driving 300D? I was thinking about hard wiring an inverter directly to the battery and having A/c plugs.. what should I do?
sethwm2 is offline
post #2 of 10 (permalink) Old 09-07-2011, 10:32 AM
Date registered: Dec 2009
I installed a separate outlet (12vdc) on the side of the consol
stevet300 is offline
post #3 of 10 (permalink) Old 09-07-2011, 10:34 AM Thread Starter
Quoted: 11 Post(s)
Could you go into a little detail about that. Such as where you wired it into and where to located it?
sethwm2 is offline
post #4 of 10 (permalink) Old 09-07-2011, 04:42 PM
MBZ300CD's Avatar
Date registered: Oct 2004
Vehicle: 1984 300CD, 1983 240TD Euro
Quoted: 62 Post(s)
I needed power for Sirius, IPOD and my cell. I had hard wired the Sirius to the existing lighter. I added an outlet to the inside of the glove box, also hard wired to the lighter in the ash tray. Then ran the USBs' out through a hole in the back of the glove box to the corner of the dash near the console. It works fine but not sure it's going to stay this way.
MBZ300CD is online now
post #5 of 10 (permalink) Old 09-07-2011, 05:16 PM
::matthew's Avatar
Date registered: Jul 2008
Vehicle: 1985 300D W123 Cali
I have a cigarette lighter (power source) in the glove box. I used the power from the light. just be sure to pull from the unswitched side. This is a key on only power source.
1985 300D cali 190K
::matthew is offline
post #6 of 10 (permalink) Old 09-07-2011, 09:48 PM
Date registered: Dec 2010
Vehicle: 77 240D
Quoted: 45 Post(s)
the side contacts on the 12v connector are springs. you may have some luck by just bending them outwards a bit more.
bricktron is offline
post #7 of 10 (permalink) Old 09-08-2011, 01:35 AM
Date registered: Feb 2009
Vehicle: 1985 500SEC; 1984 300TD; 1984 300CD; 1985 300CD; 1978 280CE
That always worked for me. I think it's a little bit wider. Probably why I always see it referee to as "cigar lighter" on wiring diagrams, etc.
I just stick a flat screwdriver behind the metal tabs and turn slightly. It makes a tighter fit.
Casey220 is offline
post #8 of 10 (permalink) Old 09-08-2011, 02:59 PM
Abu Ali's Avatar
Date registered: Nov 2005
Vehicle: 1999 CL500
Quoted: 23 Post(s)
my cig lighter 12v plug hasnt worked since 1996
@ MBZ300CD -- do you have a thread with detailed pics? I use a USB cable (from my headunit) to power my Garmin Nav; would be nice to have a seperate 12v outlet like what you brilliantly did.
'84 300D Euro 5-Speed -- Sold
'97 E420 Sport
Abu Ali is offline
post #9 of 10 (permalink) Old 09-08-2011, 08:25 PM
mike-81-240d's Avatar
Vehicle: 123.193
Quoted: 115 Post(s)
Send a message via MSN to mike-81-240d Send a message via Yahoo to mike-81-240d
Gary you copy cat!
mike-81-240d is offline
post #10 of 10 (permalink) Old 09-09-2011, 09:48 AM
Ghaniba's Avatar
Date registered: Jun 2009
Vehicle: None, moved on.
Send a message via AIM to Ghaniba
For mine, I ran a new fused wire from the battery for two new outlets. One for Satellite Radio and one for a GPS/voltmeter/other 12v gadget.
On the one with the satellite radio you can see, I have that wired where the left is constantly on / available and the right one is switched with a relay being fed trigger from the original positive at the cigar lighter.
Dave
Ghaniba is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    How many cigarette lighters in 04 CLK 320? rsidhu87 C209/A209 CLK-Class 1 05-23-2010 01:01 AM
    Cell phone chargers won't stay plugged into lighter! swich2mac W210 E-Class 6 08-18-2008 08:55 AM
    adding cigarette lighters bigdaddyd300se W126 S,SE,SEC,SEL,SD,SDL Class 15 05-03-2006 01:57 AM
    cigarette lighters posix W140 S-Class 0 10-08-2005 12:57 PM
    Cigarette Lighters Stuck stephenb W126 S,SE,SEC,SEL,SD,SDL Class 2 08-03-2004 09:05 PM
