Cigarette Lighter 1984 Mercedes 300CD - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-01-2011, 05:41 PM Thread Starter
Date registered: Aug 2011
Vehicle: 1984 Mercedes 300CD
Post Cigarette Lighter 1984 Mercedes 300CD
I went to plug in my radar detector on my 1984 Mercedes 300CD, which I just got, but the cigarette lighter input is not working. Is this a simple repair?
Thank you for your help...
samlorac is offline
post #2 of 3 (permalink) Old 09-01-2011, 07:38 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
It's probably a blown fuse. The fuse box cover is a pain to get off, just work at it. There is probably a diagram inside the cover that shows which fuse is the cigarette lighter. It's also annoying that Mercedes cigarette lighters are not the "standard" size that you are expecting, so your plug may flop around in it. Actually before you check the fuse, you should try holding the plug in the cigarette lighter and moving it ever so slightly to see if your detector lights up. Note that the cigarette lighter in your car is only on when the car is turned on.
Scoot is offline
post #3 of 3 (permalink) Old 09-01-2011, 07:48 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 207 Post(s)
The ashtray has to be fully open so the contact points trigger the cigarette lighter to activate.
Check contact points on ashtray and center console.
MBeige is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    cigarette lighter daryn R/C107 SL/SLC Class 27 08-18-2010 08:40 PM
    04 CLK 320 Cigarette Lighter rsidhu87 C209/A209 CLK-Class 6 05-21-2010 10:34 PM
    Cigarette lighter stunistu General AMG 1 01-26-2007 12:26 PM
    cigarette lighter(r) posix W140 S-Class 1 01-31-2006 05:08 AM
    Cigarette Lighter streetrules W123 E,CE,D,CD,TD,TE Class 4 06-20-2005 02:30 AM
