Fs 78-83 W123 Diesel Tachometer 300D 300TD EURO Tach RARE - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 04-27-2011, 04:35 PM Thread Starter
kugli007's Avatar
Date registered: Oct 2010
Vehicle: 1983 W123 Euro 300TD Turbo & 1987 W124 300d Turbo & 1996 W210 E320 I6
Post Fs 78-83 W123 Diesel Tachometer 300D 300TD EURO Tach RARE
Look this:
EBAY: 78-83 W123 Diesel Tachometer 300D 300TD EURO Tach RARE | eBay
HI This is the very hard to find Mercedes W123 Diesel Euro Tachometer 300D 300CD 300TD tach 2plug
This is a tachometer removed from a euro W123 diesel,they have different IP pumps on some models. This 1982 euro non-turbo has a higher redline. The US models use the same tachometer amp (years 81-83) as the euro cars. US cars can not redline because the IP pump will cut fuel. It is a plug and play upgrade with a working clock .If your w123 doesn't have a tachometer you'll need to get wiring / tach amp from another vendor, as I don't have them .
It will fit:W123 2pin 1978-1983, it will not work in the 3pin 84-85 model years if your W123 came with a tach from the factory.
This tach is in great shape/ tested!!! The clock works great!!!
kugli007 is offline
post #2 of 12 (permalink) Old 04-27-2011, 11:13 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It is an early tachometer for a 280/280E. Maybe it has been modified to work on diesels.
Govert70227 is offline
post #3 of 12 (permalink) Old 04-28-2011, 02:27 AM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
I thought of that too. The redline was a clear indication.
benzmizer is offline
post #4 of 12 (permalink) Old 04-28-2011, 03:23 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
What's the price of the tach without the wait of bidding?
Benzmizer, you still have this tach and like to part with it?
Nutz 4 Benz is offline
post #5 of 12 (permalink) Old 04-28-2011, 09:33 AM Thread Starter
kugli007's Avatar
I find other euro tach this use diesel to
ID:	372442   Click image for larger version
kugli007 is offline
post #6 of 12 (permalink) Old 04-28-2011, 11:18 AM
FratBoy's Avatar
Date registered: Jun 2006
Vehicle: 1980 280CE; 1982 300CD
Quoted: 26 Post(s)
Wasn't the last of the clock with marks for each second available in the 116? Are we sure this is a 123 tach?
I don't recall ever seeing a 123 tach/clock with seconds.
FB
The Inventory:
1982 300CD 162k (5 speed coming soon)
1982 300SD 205k with SBC 350 + TH350 FOR SALE
Those Not so Lucky:
1979 230C Euro 4 Speed 161k, more
1980 280CE US with Euro M110 + 4 speed 126k, more pics
1980 280CE Euro 4 speed 101k
1983 280E Euro 5 speed (parts only)
1980 280E Euro 4 speed 165k
1985 500SEC US (shmoove)
1982 300D US 4 speed
1978 300CD US
1979 300D US
FratBoy is offline
post #7 of 12 (permalink) Old 04-28-2011, 11:29 AM
Quoted: 4 Post(s)
It is an early W123 tach. See also this (German) page:
Drehzahlmesser im Vergleich
PlaneCrazy likes this.
post #8 of 12 (permalink) Old 04-28-2011, 11:52 AM Thread Starter
kugli007's Avatar
the google translate the page:
Tachometer compared
In particular, in auction houses like tachometers are available with the wrong map. By far the highest prices are paid for W123er DZM (80 - to 200 - €), while not pack as often W124er DZM the 20 € mark.
Here, first photos of the various W123 models for a rough distinction. Within the series of course there are other distinctions:
Diesel: 6000 IMP or 14 or 000 Hz alternator terminal W. DDZM Most have no red zone. Except very early models, which also have a clock with minute scale.
Gasoline: 4 - and 6-cylinder; for breaker point or electronic ignition, to various red areas. To 8 / 82 with silver cap on the needle. Very early models have a clock with a minute scale. There also have different zero points.
so its good for the diesel or not?
kugli007 is offline
post #9 of 12 (permalink) Old 04-28-2011, 12:03 PM
Quoted: 4 Post(s)
No, it will not work on a diesel.
The red-zone tachometers for diesel have a redline at around 4500-4600 rpm. The redline at 6500 rpm indicates a tachometer for a 280 or 280E. It will only work on a six-cylinder gas engine.
post #10 of 12 (permalink) Old 04-28-2011, 01:25 PM Thread Starter
kugli007's Avatar
Yeah u right here some sample
kugli007 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    FS OEM MERCEDES W123 300D TACHOMETER & AMPLIFIER kugli007 For Sale/Wanted/Trade/Giveaway 0 12-21-2010 03:57 PM
    Mercedes W123 Diesel Parts 300D 300TD 300CD SilverFox123 For Sale/Wanted/Trade/Giveaway 6 03-07-2010 04:24 AM
    Wanted: 1981-1985 W123 300D or 300TD Turbo Diesel dtutty For Sale/Wanted/Trade/Giveaway 1 09-19-2009 01:46 PM
    Tachometer instead of clock in W123 300D?Is that possible? b_e_z Vintage Mercedes-Benz 4 05-15-2006 12:05 AM
    Perfectly good, rare W123 LWB diesel being purposely destroyed H-TownBenzoboy W123 E,CE,D,CD,TD,TE Class 7 09-28-2005 11:32 AM
