How much tire pressure in 15's -195/65/15? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 04-19-2011, 03:04 AM Thread Starter
Carbuff's Avatar
Date registered: Feb 2004
Vehicle: 1984 W123 240D; 2001 E220 CDI W210; 2012 E250 CDI Bluetec - Avantgarde
Quoted: 4 Post(s)
Folks what is the accurate trie pressure one should maintain on a 15inch setup - 195/65/15 that I have on my 240D 1984 model? Thx
Carbuff is offline
post #2 of 13 (permalink) Old 04-19-2011, 05:57 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
I go with the recommendation on the side of the tire, max, or near.
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
post #3 of 13 (permalink) Old 04-19-2011, 09:08 AM
sd300td's Avatar
Date registered: Dec 2008
Quoted: 10 Post(s)
I still use the factory recommended pressures, 28/32 front and rear. Not sure if or how a +1 wheels size would make a difference in a tire pressure recommendation.
2005 230 K, 26k-77k (sold)
1982 300 TD, 167k-226k
1982 240 D, 308k-327k (sold)
1998 E 320, 120K-141K
sd300td is offline
post #4 of 13 (permalink) Old 04-19-2011, 09:49 AM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 335 Post(s)
Use factory pressures. I'd use the "high speed" pressures. The tyres will last longer and run cooler, although it claims to reduce driving comfort. I haven't experienced and difference in road noise or comfort, though.
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #5 of 13 (permalink) Old 04-19-2011, 11:42 AM
Date registered: Sep 2010
I personally always go about 10% less than the max on the sidewall of the tire. The suggested pressures on the car are only valid for the exact stock tires and often are lower so the car rides softer. If you run them around the max cold psi then your ride wont suffer too much and you will get better wear and fuel economy. Like now my tires have max of 45 psi so I run around 40 psi.
Giffels is offline
post #6 of 13 (permalink) Old 04-19-2011, 12:27 PM
PlaneCrazy's Avatar
Quoted: 335 Post(s)
Originally Posted by Giffels View Post
The suggested pressures on the car are only valid for the exact stock tires and often are lower so the car rides softer...
NOT TRUE! The tyre pressures are detemined by the load exerted on them by the car's mass. Read the owner's manual.
In general, you are right about harder tyres lasting longer and giving better economy, BUT they also lose traction - you could be running on just the inside of the tread rather than the full width of the tyre.
post #7 of 13 (permalink) Old 04-19-2011, 12:37 PM
[QUOTE=PlaneCrazy;4683946]NOT TRUE! The tyre pressures are detemined by the load exerted on them by the car's mass...
I agree that they are determined by the mass of the car as well as tire specifications, however I always assumed these calculations are based upon a soft ride, and 1985 rubber. The tires you buy for the car also have the load rating factored in thus it is a relative calculation for the mass of the car. There is nothing wrong with running those pressures however they are generally lower than the optimal tire wear/rolling resistance level. when you do inflate them near the cold max you also need to check for tread wear after you get some miles on them and adjust accordingly. Just my opinion, I have always found those pressures listed in cars to be like 15 psi off, mainly because they are calculated for best grip (lets face it if you are exploring the grip limits of a w123 you are driving the wrong car ) , and comfort level not necessarily wear and better mpgs.
Giffels is offline
post #8 of 13 (permalink) Old 04-19-2011, 11:38 PM Thread Starter
Carbuff's Avatar
Quoted: 4 Post(s)
Thx folks I am confused!?..cant see one line of suggestion coming...
Carbuff is offline
post #9 of 13 (permalink) Old 04-19-2011, 11:40 PM
Premium Member
ducatipaso's Avatar
Date registered: Jul 2006
Premium Member
Send a message via AIM to ducatipaso
Anything at or above what the sticker in your gas flap says will be sufficient.
I personally tend to run about 5 psi over those numbers [up to the max pressure on the sidewall of the tire] to reduce sidewall flex, reduce rolling resistance. you'll get more noise from the road at these pressures, but moving to 15s is going to introduce more noise anyhow.
ducatipaso is offline
post #10 of 13 (permalink) Old 04-20-2011, 05:46 AM
Rmac58's Avatar
Quoted: 139 Post(s)
See post #2.
'84 CD-weekender!
Rmac58 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Tire sizes 195/65/15 vs 195/60/15 for 300d swampcop W124 E,CE,D,TD Class 3 02-04-2010 02:06 PM
    Correct tire pressure for low profile tire on R129 bkksl R129 SL-Class 13 07-15-2009 09:29 AM
    Tire Rack special-195/70R14 oliverb W123 E,CE,D,CD,TD,TE Class 4 02-16-2009 08:06 AM
    taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 02:49 PM
    Last tire/rim question from me: Is this combination OK/allowed for SLK 230: 195/65-15" on 7Jx15 ? Anders Davidsson R170 SLK-Class 0 10-23-2001 01:18 PM
