Recommended Lubricants - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 04-05-2011, 08:38 AM   #1 (permalink)
boydpd's Avatar
Date registered: Sep 2010
Vehicle: 1979 240D 4 spd
Hi again - I'm about to change my manual transmission and differential oils. I know that the diff oil is a SAE 90W Hypoid gear oil. Any recommended types or brands?
Also, the manual trans uses a Type A Automatic Trans Fluid (according to Haynes). Once again, any recommended types or brands? I'm willing to pay for quality.
1979 240D 4spd - Gladis
boydpd is offline   Reply With Quote
Old 04-05-2011, 10:27 AM   #2 (permalink)
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
rear differential also 85W90
ATF type A is a very old specification, best go up a level: Dexron II or even higher, there are also specific manual gearbox oils.
MB has a site with officially recommended fluids: Mercedes-Benz Specifications for Operating Fluids: Engine Oil, Gear Oil, ATF, Coolant, Brakefluid but other brands not mentioned there can also be good.
Govert70227 is offline   Reply With Quote
Old 04-08-2011, 06:20 AM   #3 (permalink)
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '82 W123 240D, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
What would be specific gearbox oils?
I put 80w90 into my gearbox... turns out I shouldn't have. Visited the site linked above, but couldn't understand anything, other than that the Unimogs have a unique specification.
Would Dexron III be good? If not, what would be? Synthetic?
I read many of the posts returned by the "search this forum", but all I see are discussions and opinions, nothing I could put a finger on...
Donkey, decision pending
W202 C250 Diesel
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline   Reply With Quote
Old 04-08-2011, 07:11 AM   #4 (permalink)
If you want to follow the "official" route, first look in the Service Manual for the specific lubricant code. The motor oil code for the W123 is 229.1 for instance. Now click on 229.1 on the lubricant page and then you can see the recommended lubricants. You only have to select the desired viscosity.
The manual of the car also has a list of recommended lubricants.
Manual gearboxes of the W123 originally have a ATF type A requirement, but specific gear oils (235.1) are also used (also by MB dealerships), especially on worn-out gearboxes. I have used both and have noticed no difference. Type A is very viscous when cold, newer standards (Dexron II and III) are better in cold weather.
Dexron II is OK according to the
Technical Companion Technical Companion
of the MB Club USA, I don't know about Dexron III.
Old 04-08-2011, 08:23 AM   #5 (permalink)
boydpd's Avatar
I bought 80w90 for my differential.. I haven't put it in yet, but I was planning to. Is this kosher?
Waiting another 5k till I do my transmission. The lubricant in it looks real good.
Old 04-08-2011, 03:03 PM   #6 (permalink)
Recommended viscosity for rear differential is SAE 90 or SAE 85W-90. 80W-90 is widely used in W123s, but it is less viscous than it should be. I have yet to see a MB recommendation for 80W-90 for rear differentials.
Bookmarks
fuchs lubricants finder cotsios91 W209 CLK Class 0 02-26-2011 01:18 PM
R129 Lubricants Chetter R129 SL Class 13 01-27-2011 05:34 PM
lubricants Left_AMA W123 E,CE,D,CD,TD,TE Class 2 05-26-2008 08:28 PM
Lubricants and Fluids Listing pcmaher W140 S-Class 1 10-21-2006 05:10 PM
lubricants, synthetic or not? navydave W123 E,CE,D,CD,TD,TE Class 12 04-27-2006 02:58 PM
