I'm looking for the P/N (or numbers) that point/s to the rubber grommets covering the tiny holes on the engine bay wheel arch area.
In the image below you can see what I'm talking about - they're the tiny holes (some with a slit on the side) that are used to attach optional equipment to the inner fenders on our cars but for those w/o these extra equipment, MB uses the rubber plugs to cover them up. Mine are missing some and I would like to complete them. Has anybody done the same?
I had a look at the descriptions of the different plugs, but there is not one that says "plug for holes in fender". Do you have a picture of an existing one? Usually these plugs are not very expensive, you could order a bunch.
They're optional mounting points for equipment like the early style cruise control actuator (vacuum operated), ABS module, mounting for SLS reservoir, some use them for the ignition coil (see green 280 2 posts up), etc.
Could you check if those plugs have any p/n's? And photos also, please. Thanks!
As it turns out, the ones used were P/N A 000 987 18 40.
I needed 5 for the driver fender, so that's how many I ordered. Some of the holes were threaded for equipment attachment points, but those w/o made good use of these plugs.
