alternator pulley - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-14-2011, 02:43 PM Thread Starter
Date registered: Jul 2006
Vehicle: 1984 300D Turbo Diesel
alternator pulley
I pulled the alternator today and metal bits fell out of it, so I know it's toast. Everything went well, but I bent the lip of the double pulley by dropping the alternator... thankfully it didn't hit my toe...
Should I try fix the pulley by bending it back or buy a new one? I don't want to have a pulley that's going to shred belts all the time because it's not smooth and true. If I need a new one, where can I get one?
Thanks.
cbjukraine is offline
post #2 of 6 (permalink) Old 01-14-2011, 03:29 PM
Grif900's Avatar
Date registered: Jul 2010
Vehicle: 82 300D
If I were you I would try the local yunk jard. They probably wont want to sell just the pulley but sometimes we do get lucky. You may want to buy a remaned unit but it will probably come without a pulley as they are somewhat generic and you will need a good core to return. I have been back-charged for returning an unusable core. If tiny bits fell out of yours it MAY be unusable. Just my 2 cents.
Grif900 is offline
post #3 of 6 (permalink) Old 01-14-2011, 07:43 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 207 Post(s)
The pulley is quite expensive new, I agree to get a used one. See if members are parting cars out.
When installing the "new" (brand new or used) pulley, make sure you also get the key IIRC to install this pulley to the alternator shaft. If old one is good, reuse.
MBeige is offline
post #4 of 6 (permalink) Old 01-15-2011, 05:58 PM Thread Starter
I called a local MB dealer: $180 for the pulley. I hate that about MB. but I found a working alternator at the junkyard today, so I'm going to ride that until it gives out...
post #5 of 6 (permalink) Old 01-15-2011, 06:59 PM
MBeige's Avatar
Quoted: 207 Post(s)
Wow, 4-5 years ago it was $100.
Yeah, had to replace the pulley on mine too. Alternator shaft was badly damaged, had to upgrade to 65A from original 55A even if original unit was fine except for the bad mechanical aspect.
MBeige is offline
post #6 of 6 (permalink) Old 01-15-2011, 10:33 PM
Date registered: Sep 2010
I have a double pulley from the 120AMP alternator I am about to install. I don't need the double pulley, and Am using the single, if we are talking about the same part I could give it to you, brand new
fleebailey33 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Alternator Pulley adam94 W140 S-Class 5 06-23-2009 07:48 PM
Replaced Alternator pulley DYB V-Class 1 04-24-2008 09:58 AM
alternator pulley GeoTiger W123 E,CE,D,CD,TD,TE Class 2 11-28-2006 04:35 AM
Alternator Pulley turboroad W123 E,CE,D,CD,TD,TE Class 3 08-05-2006 06:33 PM
alternator pulley wheel? jessfx W201 190-Class 2 01-25-2006 02:21 PM
