OM617 cruise install ...possible?? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-07-2010, 09:28 PM Thread Starter
Date registered: Apr 2010
Vehicle: 1987 Marcedes 300GD (LWB) diesel 3L. 5 speed
Hi,
Did some searching and cant really find any info .
I have Mercedes 1987 300GD non turbo with OM617.931, manual 5 speed . Im looking for any istructions,possiblity of installing cruise control to this pedal line control acelerator diesel engine. How hard this would be? is it safe ? does it require tearing steering column apart ? what parts would i need ? appreciate any info .J
jaca300GD is offline
post #2 of 11 (permalink) Old 11-08-2010, 02:13 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
There are aftermarket cruise controls (in Europe sold by Waeco) which can be installed on your car. It can even be made to work with the original MB cruise control handle.
Or you buy the original stuff. New it is very expensive. If you buy it second-hand, the electronics might not work properly.
Govert70227 is offline
post #3 of 11 (permalink) Old 11-08-2010, 02:59 AM Thread Starter
any idea what kind of instalation work it requires ? Tnks
post #4 of 11 (permalink) Old 11-08-2010, 03:57 AM
Quoted: 4 Post(s)
The following items need to be installed:
- speed pickup sensor (on the driveshaft)
- shut offs switches for the clutch and brake pedals
- actuator in the engine bay which works the gas linkage
- on/off/resume/coast/accelerate switch (which can be the original MB handle, but can also be aftermarket).
and the wiring to the electronic control unit from and to all those components.
post #5 of 11 (permalink) Old 11-08-2010, 05:46 AM Thread Starter
Thank you Govert.
Now just need to see if can source all these parts here and need also wiring diagram possibly install instructions.
post #6 of 11 (permalink) Old 11-08-2010, 06:04 AM
Quoted: 4 Post(s)
Here is a link to the Waeco cruise controls:
WAECO mobile solutions - Cruise controls
They come with the parts and the wiring instructions. I don't know whether that is available in Canada, but there must be sets like that, or it is available under a different name.
post #7 of 11 (permalink) Old 11-08-2010, 06:25 AM
MerzDiesler's Avatar
Date registered: Mar 2008
Vehicle: 1981 240D
Govert: This is a good discussion. Fixing my cruise control is high on my priority list for my 1981 240D (4 Spd Manual). It has all the cruise control components installed. The cable from the actuator seems to have been cut. Any ideas why someone would cut this cable? I guess it is possible that it broke, but everything else in the engine compartment is fine. What would be the first thing you would check?
'81 240D 364,916 Miles, Little Champ!
'92 190E 222,000 Miles (SOLD)
'83 300SD 493,653 Miles, Running STRONG! (SOLD)
'74 450SEL 144,000 Miles, BAD FUEL SYSTEM! (SOLD)
'07 Toyota Corolla, Not quite a MB (STOLEN)
Yuma, Arizona, USA
MerzDiesler is offline
post #8 of 11 (permalink) Old 11-08-2010, 06:40 AM
Quoted: 4 Post(s)
Do you have this type of actuator?
That is vacuum controlled, which can leak and not function properly anymore.
The original electronic control unit can have some troubles too after 30 years (sometimes resoldering and refitting capacitors gives it a second life).
post #9 of 11 (permalink) Old 11-08-2010, 06:44 AM
Vehicle: 1981 240D
That's the one! That is exactly what I have. The cable that comes off the end and goes to the throttle linkage is a 'Bowden' cable. It is broken/cut from the linkage. Will this type of cruise control also have a control module? If so, do you think I should replace the actuator first, then work on the control module as needed? I am also pretty sure I need to replace the switch on the steering column since it seems difficult to operate. Might be corroded contacts inside.
Yuma, Arizona, USA
post #10 of 11 (permalink) Old 11-08-2010, 06:57 AM
Quoted: 4 Post(s)
You can repair the original system using the FSM:
54 Chassis Electrical, Instruments
Select the Cruise Control Pneumatic.
It has a electronic control unit.
What things needs to be repaired first is difficult to say. You can connect the bowden cable and see if it works at all (try it on an empty road) and use the tests described in the FSM to see what is the problem.
...or you can install an aftermarket system.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Cruise controll install on my w210 augu W210 E-Class 6 01-24-2011 09:36 AM
Can I install cruise? david55838 W126 S,SE,SEC,SEL,SD,SDL Class 6 05-08-2009 06:22 PM
Getting more out of a NA OM617 VonEpp W123 E,CE,D,CD,TD,TE Class 18 02-20-2009 07:31 AM
anyone up for a mb cruise or maybe just a clk cruise?? northeast.. redflames C208/A208 CLK-Class 1 05-28-2008 10:26 AM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 09:34 AM
