Help! Need specifics on MPG 300d and sd - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 06-20-2010, 08:36 PM Thread Starter
mrbondmi6's Avatar
Date registered: Jun 2010
Vehicle: 1981-85 300sd (not sure yet)
Hello, I'm considering purchasing a 1981-1985 300d or sd but I'm not getting any solid gas mileage figures.
My commute is about to be 80 miles a day and I thought an old reliable Mercedes diesel would be the perfect vehicle for my mostly highway commute. The problem is looking through this forum I'm getting all kinds of figures. 18-35 MPG.
Any advice would be much appreciated!
Thanks.
mrbondmi6 is offline
post #2 of 16 (permalink) Old 06-20-2010, 09:06 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
The weight and aerodynamics (or lack thereof) of either chassis can have a negative impact on fuel mileage. Mileage also suffers at highway speeds due to final drive ratios resulting in high engine RPM. Engine condition also contributes to mileage and can explain the wide range in figures.
123 and 126 diesels made excellent long-distance commuters due to their reliability, ease of maintenance, and comfort.
I made a 60 mile per day commute in a 300 D for years; the chassis failed before the drivetrain, which was perfect at over 410,000 miles.
jdc1244 is offline
post #3 of 16 (permalink) Old 06-20-2010, 09:40 PM
Have driven 2 300 SD's for over 300,000 miles. Still own one, an 84. With a fresh tuneup I routinely averaged 29-31 MPG on the freeway at between 55-70 MPH. This routinely gave me 600 miles with reserve on a tank of diesel, not gas. One the station slipped me $10.00 in Premium and the engine was toasted by the time I realized that something was the matter except for unusually high fuel useage. The station responsible replaced the engine with a junker engine that used excessive oil and fuel and blew in 4,000 miles. Still have car but it was replaced with an 84. Again with a new cam chain, replace timing chain every 200,000 miles and tune up every 25,000, and of course change all 8 liters of oil with a good oil, Not Chevron or Valvoline or Castrol. Keep the injector timing at 17.5-18.5 degrees after top dead center. and you will keep optimal performance for open road mileage.
Tom Hardy is offline
post #4 of 16 (permalink) Old 06-20-2010, 10:15 PM
MBZ300CD's Avatar
Date registered: Oct 2004
Vehicle: 1984 300CD, 1983 240TD Euro
Quoted: 61 Post(s)
Before I retired I used to drive 140 mile round trip for work, 90% freeway. When I drive at 70+/- or with the flow of traffic, I got a pretty consistent 25 MPH. For the last year and a half before that because diesel went over $5 a gallon, I drove a consistent 55 MPH, always using Cruise Control. I averaged 30+ MPG. It can be a bit scary to drive like this. Since I no longer do that commute, it has dropped significantly. You can see it in the graph below. If you click on the graph you can read any comment, about the driving conditions, I may have made about that particular tank of fuel.
Gary
1984 300CD, Exterior Code # DB877 Petrol - Blue/Green Interior Code #155 MB-Tex Creme
"Even more attractive than this coupe's classic lines are it's classic over-the-road capabilities".
Mercedes-Benz of North America 1984 range brochure
SR 395 @ Mono Lake, CA
MBZ300CD is offline
post #5 of 16 (permalink) Old 06-21-2010, 05:33 AM Thread Starter
mrbondmi6's Avatar
Thanks guys, all of this is great news.
What about simple after market mods - like a K&N air filter?
This is interesting since not a single responder has mentioned sub-25 mpg.
post #6 of 16 (permalink) Old 06-21-2010, 12:39 PM
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro found dead on Ebay
how is that possible??
even at 7,500 lbs this guy gets 25 mpg.
cheapold280ce is offline
post #7 of 16 (permalink) Old 06-21-2010, 12:43 PM
Premium Member
ducatipaso's Avatar
Date registered: Jul 2006
Premium Member
Send a message via AIM to ducatipaso
a realistic figure would be more in the low/mid 20 range unless you have the deathwish of driving 55mph
ducatipaso is offline
post #8 of 16 (permalink) Old 06-21-2010, 05:08 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
What about simple after market mobs - like a K&N air filter?
Here's your first sub-25 mpg response. I average about 22mpg combined driving in the 1982 300D Turbodiesel.
Also, K&N will not help you. Unlike other makes, your stock filtration system and stock filter is more than sufficient for your engine.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #9 of 16 (permalink) Old 06-21-2010, 06:32 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 200 Post(s)
I average around 23-24mpg combined. Fuel consumption increases when I use AC, more so when I hit 80mph on a regular basis. If I drive 60-65mph, I can get it up to 26mpg without AC. With AC, that drops to around 24.
If you want to see better MPG, check eBay
MBeige is offline
post #10 of 16 (permalink) Old 06-21-2010, 07:38 PM
240_benz's Avatar
Date registered: Oct 2008
Vehicle: 1985 380SE
People say they notice a significant difference with the K&N setup yet they fail to provide real numbers before and after the changeover.
The stock air filtration setup provides more than enough air for the engine to breath so leave it as is.
1982 240D - Daily rig
1985 380SE - Gone but not forgotten
1987 Vanagon - Sold
Looking for a 300SD, TD or TE
240_benz is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    300D MPG Question! LDesign W123 E,CE,D,CD,TD,TE Class 36 09-13-2015 08:13 PM
    76 300D only getting 22.8 MPG SakoTGrimes Vintage Mercedes-Benz 11 01-23-2012 04:22 PM
    75-76 300d mpg sgormani Vintage Mercedes-Benz 2 02-01-2007 11:49 PM
    300d Turbo Diesel Economy Mpg Question. 22city 25hwy ?! Anri_300D Turbo 85 W123 E,CE,D,CD,TD,TE Class 4 08-11-2006 11:34 PM
    Fuel economy (MPG) for '87 300D? stuttgart W124 E,CE,D,TD Class 10 08-13-2004 11:37 AM
