I'm getting ready to put the oil pan back on my 1985 300TD with a new gasket.
I've read that the bolts need to be torqued to:
Oil pan bolts 9-11 Nm (6-8 Ft Lbs 79-97 Inch Lb )
My torque wrench goes from 5-80 ft. lbs. in .5 lb increments.
Should I start at 6 and work a pattern around the pan tightening each bolt? Is there a recommended tightening pattern or do you just try to star pattern it the best you can like lug bolts and just keep tightening them up to 8 ft. lbs if there are leaks?
I may be making more out of this than I need to, but I would like to make sure I get a leak free oil pan on the first try. The oil pan was a leaking mess prior to this and leaked heavily along the entire back straight edge.
Yes.
Although, I've never used a torque wrench. As a precaution against a leak, you may consider brushing some Permatex brand Aviation sealant on the engine, oil pan, and both sides of your gasket. You don't need to apply it liberally, just a thin, covering layer. I have never needed to use this gunk on my oil pan gasket, but it has worked so well for me in stopping other leaks on my 123 and all my other cars that I'll probably just use it next time for good measure.
Generally, my tightening pattern would be sides, corners, and then everything in between.
__________________ My vehicles:
59 220S Sedan | 83 300 CD | 00 C230 Kompressor | 89 911 Carrera | 05 911 Carrera | 03 Explorer | 06 Odyssey Other vehicles I work on:
94 S 420 | 08 CLK 350 Coupe | 09 ML 350 | 00 323i | 01 330i | 03 X3 | 07 335i | 02 Jetta GLS Turbo | 03 Passat | 01 S60 T5 | 83 XJ6 | 03 Pathfinder | 08 RX 350 | 96 Blazer | 07 Silverado 1500
Hey I'm about to change the oil pan on my 84 280E and was wondering if you happened to use that Permatex brand Aviation sealant and if so how's everything holding up?
1998 Mitsubishi 3000GT SL - Garage Kept/Weekend Driver/FOR SALE
1984 Mercedes Benz 280E - DD
I know it's expensive but if you really need to use a gasket sealer for the pan ask for Mercedes black RTV at the dealer. It comes in a medium size tube for $35 ($20 with MBCA discount!). The master techs I know swear by it if it isn't a trans seal.
1984 300D "Elsa"
1983 300TD "Mitzi" 268,XXX
1995 E300 "no name yet" (wife's car)
Stock except for egr welded shut, LubroMoly 5w40, Mobil 1 syn in diff.
