Flat Tire sound, no flat tire???? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 03-17-2010, 07:46 PM Thread Starter
Date registered: Oct 2008
Hello
I've owned my 84 300d for about a 1 1/2 years now. I've been going through it and doing all the maintenance stuff, you guy have talked about. I change the oil and filters regularly, fixed the some vacuum problems (locks, and the trans shifting hard), removed the egr. And was going to adjust the vavles this weekend. But on the way home from taking my wife to the doctors, today. About 2 miles from our house. I heard what sounds like a flat tire in the back. So I pulled over at a gas station to check. And all the tires are fine. So I continued to drive home, and the sound also continued. Once at home I jacked each side of the rear and spun the tires in Neutral. It seems like the sound is more from the passager side. But sounds like its coming from the diff. Didn't notice it from the drivers side. Now both half shafts have warn boots. I haven't done any thing back there yet. Figured I start at the front and work back.
So my question is has anyone else ran into this problem, and where should I start Axle or diff?
Thanks
fuzzyredhelmet is offline
post #2 of 17 (permalink) Old 03-17-2010, 07:59 PM Thread Starter
That just it, the car handles and steers fine. No shaking it's just sounds like it has a flat tire.
post #3 of 17 (permalink) Old 03-17-2010, 09:20 PM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
Put it back up (safely) so that you can spin the Wheels powered by the Engine and listen with a Mechanics Stethoscope (cheap at Harbor Freight) and see if you can localize the sound. Or, you could listen as I do with a length of Wooden Broomstick.
You could also check the Rear wheel Beaing end play. You are supposed to use a Dial Inicator for that (also a Harbor Fright item) but if you can feel any play at all just pushing in and out on the Hub by hand.I would be concerned; and have it checked with a Dial Indicator for sure.
Also take a look at the Rear sway Bar Links for breakage or too much play (they are plastic).
Also it could be the Rubber Bushings at the top of your Shock Absorbers has rotted out.
300Dman is offline
post #4 of 17 (permalink) Old 03-17-2010, 09:43 PM Thread Starter
Thanks I'll try that tomorrow afternoon. I have the tools you mentioned. So that no problem. Also going to change out the diff fluid. To see if I can find anything in there.
post #5 of 17 (permalink) Old 03-18-2010, 04:03 AM
Ghaniba's Avatar
Date registered: Jun 2009
Vehicle: None, moved on.
Send a message via AIM to Ghaniba
I have the same phantom noise in my new(er) 84. It did it once after taking a harder than normal left. I put it up on the lift and checked for any problems. I found a ripped boot on my passenger side axle. While spinning it, at one point there's a very light "chop" sound which under weight could certainly sound like the flat tire "flop" sound, I figure.
I lowered it back down, and drove it again... and couldn't get it to make the noise again. Mind you, it was about 5 miles I drove it with the noise before, so I was pretty surprised to not hear anything... I drove it another 2.5 weeks without hearing a sound... until yesterday, I took a right quicker than I normally do (I live in the sticks, it's part of the fun!) not overly aggressive or anything but boom, sound came back again.
I'm going to buy an axle today. I knew I was going to be buying one, since I saw the boot was ripped, but I have a hard time replacing something that's not even making noise. Thrifty or stupid, I'm not sure. Perhaps a bit of both! I'll keep you posted on my findings too.
Dave aka Ghan
Ghaniba is offline
post #6 of 17 (permalink) Old 03-18-2010, 10:32 AM
Date registered: Jul 2008
Vehicle: 1985 300td, 1983 Datsun Maxima Diesel
Originally Posted by fuzzyredhelmet View Post
Hello
Thanks
Hi
Thump, thump, thump is classic sound when half axle CV joint fails.
Joseph
jkubica is offline
post #7 of 17 (permalink) Old 03-18-2010, 11:20 AM
Date registered: Mar 2009
Vehicle: 1967 300
Definitely check your axle boots. I'm guessing that they ruptured.
On mine, my boots ruptured and I ended up driving on a torn boot for 1500 miles. I discovered the battle wound when I was home during break.
What I did was fill the boot up with this chevron gear grease. It was thick and goopy and then wrapped the entire joint in duct tape. This held for quite a long time about 3,000 miles in fact.
On a side not I'm having this thunkity thunk noise from the front right of my vehicle. What do you guys think it is?
-420SEL 213,000
areusche is offline
post #8 of 17 (permalink) Old 03-18-2010, 03:47 PM Thread Starter
Ok today I went to the store and got the stuff to change to rear end fluid. But nobody had a 14mm allen wrench. I had to order one from Amazon. So I check the lug nuts, and the suspension parts. All are fine, also it wasn't making the noise when I spun the wheel by hand. So I went for a short drive (1 mile) and the noise was gone. It seems like what Ghaniba was saying is happening here as well. I'll take it to work tomorrow, to see if it happens again.
post #9 of 17 (permalink) Old 03-18-2010, 04:04 PM
Date registered: Dec 2007
Vehicle: drive: 1983 300D turbo ======== renovating: 1969 280 SE
I had the same kind of sound only I got bad shaking above 40mph. The culprit in my case seems to have been that the rubber "skirt" that holds the center bearing in place was ripped. I replaced it and it works fine. It didn't appear ripped until I got really close to inspect it so you may want to check it out.
1983 300D turbo
1969 280SE
Anarchy - It's not the law, it's just a good idea.
ehrichweiss is offline
post #10 of 17 (permalink) Old 03-18-2010, 04:32 PM
Hi
When you get your wrench, its a good idea to remove the fill plug first. These plugs can be very tight and its important to clean out the plug so that the wrench fits well and all the way in. Otherwise you may round out the plug. You may need a cheater pipe as well as the breaker bar. Some members have even used a jack to force the wrench.
The reason for doing the fill plug first is that if you get the drain plug out and then cant remove the fill plug - you have no way refill it with oil.
Joseph
jkubica is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    had a flat tire FL_C63AMG W204 C63 AMG 15 07-23-2008 10:08 AM
    Flat tire yuna_ronald W245 B-Class 19 05-20-2008 12:28 PM
    Flat tire BENSIN C208/A208 CLK-Class 10 12-11-2007 12:59 PM
    Got a flat tire and.. uptown W163 M-Class 6 09-12-2006 11:04 AM
    WARNING! Tire Minder gave me a flat tire. (And almost a second). HEX20 R170 SLK-Class 8 09-19-2003 10:52 AM
