Convert your alternator to an external regulator.. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-03-2010, 08:37 AM Thread Starter
Date registered: Dec 2007
Vehicle: drive: 1983 300D turbo ======== renovating: 1969 280 SE
Ok, I promised I would post back on this once I'd done my research and now here I am.
Why did I do this? My car keeps blowing the voltage regulator probably due to the heater blower. Yes, I need to fix the blower but it's winter and I don't have time for fixing both an alternator AND blower. I have an alternator with a lifetime warranty but after 2 alternators in 2 weeks(actually 5 alternators in 6 months), it got clear pretty quickly that it would be easier to change out a voltage regulator, especially if it were external. In parts this cost me all of $20-ish dollars.
I would love to give a long, detailed writeup but this article was what got me to working out what I needed to do and I wound up following his steps to the word with only a few modifications so I could revert back to a normal alternator at any time.
TurboBricks | High Performance Volvo Club
Really the only difference is that there is no "light" terminal on any of the alternators I had available(and I'm pretty sure they don't exist but as always YMMV) so you have to cut the wire that goes to the small terminal on the back of your alternator plug and use that for your "I" and "S" connections. I split the wire with a male/female connector set so that if I need to use a normal alternator, all I have to do is remove the external regulator's connectors and plug them into one another to complete the circuit as normal.
TADA!! I won't be blowing any more regulators that will require me to pull the whole damn alternator out to replace.
And when they say to bend back the metal tabs or else your battery light will stay on, that is NOT what happens in a Mercedes(I neglected to do this at first). Instead your battery discharges slowly through your alternator when your car is turned off, no light will show, Be sure to bend both of them back, the one on the scrapped regulator and the one inside the alternator; nothing major, just enough so they don't touch.
That's really all there is to it. It took me a week of planning and a couple days of experimentation to get it right but now anyone can convert to the super cheap external regulators since I know it actually works.
Have fun.
1983 300D turbo
1969 280SE
Anarchy - It's not the law, it's just a good idea.
ehrichweiss is offline
post #2 of 3 (permalink) Old 03-03-2010, 12:37 PM
pidgy999's Avatar
Date registered: May 2008
Vehicle: 1980 280ce
Send a message via AIM to pidgy999
Nice! I may try this. I have problems keeping the battery charged as well. I have a new alternator and new battery, but if I run the blower on high, it discharges.
pidgy999 is offline
post #3 of 3 (permalink) Old 03-03-2010, 12:38 PM
pidgy999's Avatar
Vehicle: 1980 280ce
Oh wait, let me stop lying. It's a rebuilt alternator, not new.
pidgy999 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Alternator or Voltage Regulator? Gregs300CD W123 E,CE,D,CD,TD,TE Class 17 09-18-2015 08:45 AM
internal and external fan alternator Heav-e-d W201 190-Class 3 02-12-2007 10:18 AM
RECALL: ALTERNATOR REGULATOR BILLSONG W163 M-Class 3 04-20-2006 02:22 PM
Alternator regulator replaced Htown W126 S,SE,SEC,SEL,SD,SDL Class 8 10-30-2005 04:38 PM
alternator and voltage regulator HELP! saporter W201 190-Class 5 03-28-2005 11:18 PM
