front coil spring removal question - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-01-2010, 08:27 PM Thread Starter
Date registered: Oct 2009
So I am trying to remove my front coil springs, as I am trying to loosen the top mounting suspension nuts in the engine compartment the center rod turns, I cannot seem to keep the center rod still while turning the nuts, I need help holding the center rod still any suggestions?
Total noob soon to be expert.
DVRDCT is offline
post #2 of 6 (permalink) Old 03-01-2010, 08:41 PM
P4olom's Avatar
Date registered: Oct 2006
Vehicle: 1982 240d, 2007 e350
Quoted: 2 Post(s)
You may need a spring compressor. Good luck they are expensive. But there are 'klone' versions out there
1982 240d Light Ivory-623.
190,000 miles (as of September 15, 2008)
188,000 miles (as of March 18, 2008)
185,000 miles (as of February 21, 2008)
183,000 miles (as of October 29, 2007)
P4olom is offline
post #3 of 6 (permalink) Old 03-02-2010, 08:55 AM
rrgrassi's Avatar
Vehicle: '82 300D
Are you removing the shocks or the springs? You need the Klann type spring compressor to compress and remove the springs.
Shocks are different. If you are replacing them, you can use vice grips to hold the center rod to remove the nut and bushings.
RRGrassi
82 300D 278,000 Warndreicke in the trunk. odo repaired--again
06 Jetta TDI 100,000
rrgrassi is offline
post #4 of 6 (permalink) Old 03-02-2010, 09:21 AM
winmutt's Avatar
Date registered: Sep 2005
Vehicle: money pits of various forms
Quoted: 95 Post(s)
Send a message via AIM to winmutt Send a message via MSN to winmutt
6mm wrench should slip on the flat parts of the shock.
winmutt is offline
post #5 of 6 (permalink) Old 03-02-2010, 10:34 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
Just clamp a big vice grip on the shiny part exposed in the spring. But don't use the vice grip when you install the new shock.
Nutz 4 Benz is offline
post #6 of 6 (permalink) Old 03-03-2010, 11:56 AM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
Since it is most likely the Shock Absorbers you are speaking of you will not need a Spring Compressor.
But, I thought I would speak of compressing the Front Sprints. The Frong Springs must be at the lease 3 times stronger than the ones on the Springs on the Rear.
The Generic Spring compressores that are sold in the US are too weak.
You can look on eBay and you will see the copies and some times the Real Klann Spring Compressore that is best to do the job.
If you were in the US the PeachParts forum has a tool rental program. In New Zealand maybe you guys need to form a club so that tools can be shared.
300Dman is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Front coil spring support broke UncleBenz W210 E-Class 28 04-22-2016 05:30 AM
    Coil Spring Removal Tool MtL-BenzZ W201 190-Class 12 12-11-2009 02:48 AM
    WTB: Front coil spring W203 Vonhazelwood For Sale/Wanted/Trade/Giveaway 1 05-18-2009 05:20 PM
    front coil spring ewan69 V-Class 0 04-09-2007 04:32 AM
    Front Suspension Coil Spring Just Snapped JP1 W210 E-Class 11 01-08-2006 04:07 AM
