Inline fuel filter????? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 02-24-2010, 08:50 PM   #1 (permalink)
Date registered: Feb 2010
Vehicle: 1979 Mercedes-Benz 300D
1979 W123 300D. Looking to do a diesel purge and change all the filters. I have looked everywhere and do not see a inline fuel filter. The spin on type filter is right there in plain site...so is there not a inline on these cars? Or did the previous owner remove and/or not replace?...Thanks
rollindirty is offline   Reply With Quote
Old 02-24-2010, 08:55 PM   #2 (permalink)
Date registered: May 2005
Vehicle: 1985 300CDT, 2004 SLK 320 SE, 2012 C300
Look down by the injection pump. In the proximity of the motor mount.
When was the last time the fuel strainer was replaced?
Zill.
Zill is offline   Reply With Quote
Old 02-24-2010, 08:56 PM   #3 (permalink)
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W123, W201, W124
There should be one before the lift pump.
Old photo, but it's beside the old style (white cover) primer pump
Youngtimer
MBeige is offline   Reply With Quote
Old 02-25-2010, 07:23 AM   #4 (permalink)
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
I should be between the lower metal fuel line and before the primer pump.
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is offline   Reply With Quote
Old 02-25-2010, 06:49 PM   #5 (permalink)
Take a look at this pic. I believe there is no filter there, black hose from metal line next to white cap???? Thanks for the time...
I have not had this car a week. Don't know about the fuel strainer...Any other maintenance items you can send me would be great. Thanks
Old 02-25-2010, 07:11 PM   #6 (permalink)
mdanielson's Avatar
Date registered: Dec 2008
Vehicle: 1984 300D 363,000 miles 1996 e300d 240,000 miles 1983 300SD 168,000 miles Ascot Grey
in case those guys are off-line, i'll answer... you're belief is correct; the filter is not there. The line you mention should be in two pieces, and the filter should be in the middle, the 90 degree part pointing toward the white cap you mention. That white cap is the old style plunger on the lift pump. This is what gets the fuel to your injection pump. The white thing unscrews (ccw), then pumps up and down to prime the filters, etc. The new, cheap bosch model ($13 from autohausaz.com) just screws on and is a very easy/gratifying fix.
You can pull the fuel line off of the right side of the lift pump, stick an inline filter on it, then find a couple of inches of the same fule line to connect the 90 degree side to the lift pump. Cheap and easy, and you will have corrected a serious wrong (unless the p.o. put the filter somewhere else). Don't forget to round up a couple of hose clamps too.
1984 300d 363,000 Miles
1996 e300d 242,000 Miles
1983 300sd 168,000 Miles Ascot Grey!
1990 Dodge D250 5.9 Cummins 1st Generation
Savannah GA
mdanielson is offline   Reply With Quote
Old 02-25-2010, 09:15 PM   #7 (permalink)
Huge Help! Thanks!
Old 02-26-2010, 08:02 AM   #8 (permalink)
Rmac58's Avatar
Here's mine. Boy, does it need changing!
I have the new style primer pump, the + sign in red, replaces the white knob one.
You can tell I have plenty of line there, 5/16. This way I can lift it up to swap it out without spilling any fuel.
Inline fuel filter?????-fuel-filter-primary-pump-circled-medium
Old 02-26-2010, 11:55 AM   #9 (permalink)
Date registered: Nov 2009
Vehicle: 1982 300D Turbo, 126xxx miles
Heh, I bet the PO must have ran into issues with the inline clogging up constantly, as that is probably the only reason someone would make such a drastic change. I'm guessing dirty veggie oil...
eggosucka is offline   Reply With Quote
Old 02-26-2010, 08:35 PM   #10 (permalink)
Thanks to all for the intel. I ordered a inline along with that new style primer pump. Its gonna take me a bit to get her right...
Bookmarks
Inline vacuum filter results MBeige W123 E,CE,D,CD,TD,TE Class 14 01-18-2008 12:04 AM
question about inline and spin on filter DarkManX4lf W123 E,CE,D,CD,TD,TE Class 5 01-29-2007 02:57 PM
Inline vacuum filter element MBeige W123 E,CE,D,CD,TD,TE Class 5 04-27-2006 02:23 PM
Inline fuel filter CplRowland W126 S,SE,SEC,SEL,SD,SDL Class 9 04-04-2006 11:10 AM
Inline vacuum filter KLACKO W123 E,CE,D,CD,TD,TE Class 5 12-10-2005 05:53 PM
