» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 02-06-2010, 09:04 PM   #1 (permalink)
Date registered: Dec 2009
Vehicle: 1981 300TD Turbo wagon
air cleaner mount for 300td
Are three rubber air cleaner mounts having different height? Is the one closer to firewall is the highest. what are the exact size of these three mounts? This question is for 1981 300td. Thank you.
WANTAMB is offline   Reply With Quote
Old 02-06-2010, 09:33 PM   #2 (permalink)
Date registered: Mar 2008
Vehicle: 1984 300D
I do not believe they are different heights when new.
I would check your favorite internet parts place and see if they sell different sizes.
300Dman is offline   Reply With Quote
Old 02-06-2010, 09:44 PM   #3 (permalink)
Date registered: Nov 2008
Vehicle: 1981 300TD 265k
They are all the same size on my 81 TD, but I am pretty sure they have been replaced at some time. I read that the originals were square sided and mine are round.
carpenterman is offline   Reply With Quote
Old 02-07-2010, 04:58 AM   #4 (permalink)
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
Send a message via Yahoo to Rmac58
I believe all are the same height. The original, early ones, were shaped so you could get a wrench on 'em, the new ones are round.
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is offline   Reply With Quote
Old 02-07-2010, 07:21 PM   #5 (permalink)
Thanks all for help.
I think maybe the PO was using incorrect rubber.
Just noticed that the T-shape air cleaner support bracket has a crack, could this the result of worn engine mounts?
seems I have to replace the T-shape bracket and all three rubbers.
Old 02-08-2010, 07:02 AM   #6 (permalink)
Rmac58's Avatar
^ Unknown, but that bracket is a failure item.
Old 02-08-2010, 03:42 PM   #7 (permalink)
Vehicle: 1984 300D
Anything that causes more than normal Engine Vibration makes it possible to shorten the life of the Air Cleaner Support Bracket.
I have also read that the Asian made replacement Brackets do not hold up as well as the original.
A different one from a Junkyard would not cost much.
1990 Air Filters for Air Cleaner Installation Rolexmonger R129 SL Class 3 07-22-2009 12:50 PM
Air cleaner C320 mmarshall911 W203 C-Class 1 03-02-2009 03:27 PM
Need Air Filter/Cleaner Assembly 1985 300TD Woofy85 300DT W123 E,CE,D,CD,TD,TE Class 4 03-01-2007 01:40 PM
air cleaner ross h W126 S,SE,SEC,SEL,SD,SDL Class 6 11-14-2005 12:25 AM
air cleaner upgrade lancer W123 E,CE,D,CD,TD,TE Class 12 08-19-2004 07:51 AM
