Failed NY inspection due to frame rot... - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-18-2009, 06:11 PM Thread Starter
gf70sShow's Avatar
Date registered: Sep 2008
Vehicle: 1985 300D, 1981 300TD
Unhappy Failed NY inspection due to frame rot...
Is this an endgame for my wagon? I was just starting on the project but really did not see the frame of the badger being its downfall... I obviously have money into the car already but if it would be too costly to repair something like that (I have no knowledge on this type of thing) I think I would have to part it due to my inability to sell a car to somebody knowing there is an issue fatal issue (I hope my PO had no prior knowledge). Words of wisdom?
Thanks guys
1981 300TD "The Badger"
1985 300D
If you get confused, listen to the music play.
gf70sShow is offline
post #2 of 11 (permalink) Old 09-18-2009, 06:24 PM
akimball442's Avatar
Date registered: Nov 2007
Vehicle: '73 450SL, '83 300CD, '01 E320 4matic
Quoted: 10 Post(s)
Where in upstate are you?
-Aaron
ASE Master tech, specializing in electronics and driveability.
Certified Diesel Master tech.
EPA 609 certified
2001 E320 - 4matic - daily driver
1973 450SL - 191K - Summer Toy
1983 300CD -170K
1989 300SE - on to the next owner
1981 Coupe DeVille.. just because.
1983 Chevy Suburban Diesel... workhorse.
... and many more past and present...
Because Safety is not a luxury. Mercedes-Benz. Engineered like no other car in the world.
akimball442 is offline
post #3 of 11 (permalink) Old 09-18-2009, 06:45 PM Thread Starter
gf70sShow's Avatar
Glens Falls- between Saratoga and Lake George
you?
1985 300D
post #4 of 11 (permalink) Old 09-18-2009, 06:46 PM
Quoted: 10 Post(s)
you?
Verona, exit 33 on the thruway.
Where is the rot? Any pics?
If it's all over, cut your losses and forget it. If it's in one spot, it could be patched, and another inspector might let it slide.
-Aaron
EPA 609 certified
1983 300CD -170K
post #5 of 11 (permalink) Old 09-18-2009, 07:05 PM Thread Starter
gf70sShow's Avatar
no pics, I really didn't ever notice anything being under the car quite a bit and all, so I was surprised, but at the same time... its just one of those cars. Fuggly and always a nasty surprise when you least expect it.
1985 300D
post #6 of 11 (permalink) Old 09-18-2009, 07:41 PM
Quoted: 10 Post(s)
Well, a lot of brilliant inspectors might suspect that the rocker panels are part of the frame, they like to rust, but further under are two 'frame' rails and I've seen those rust too, where it comes together in the area between the front and rear doors.
The nice part is that if it's isolated, everything is fairly square, and it should be easy to clean up around the nasty spot and weld in some new metal. Then you can do some fancy undercoating work and maybe you could get it through for another year.
If getting it right means making a patchwork quilt out of the undercarriage, then it's probably not worth the effort, but if it's in one specific and concentrated spot, it's probably worth it to repair if you have some money into this car.
-Aaron
EPA 609 certified
1983 300CD -170K
post #7 of 11 (permalink) Old 09-18-2009, 07:59 PM
Date registered: Jan 2009
Vehicle: BMW 635CSi 5-speed
Send a message via AIM to cleeves
I've heard of people doing the old "slip a 20 in their pocket" so it will pass inspection.
cleeves is offline
post #8 of 11 (permalink) Old 09-18-2009, 08:40 PM Thread Starter
gf70sShow's Avatar
haha, my buddy did auto sales last year and whenever anybody would do inspections on friend's or employee's cars they would always make sure there was a car in the port next to it, sometimes they would miss the proper exhaust pipe, and put the emissions testing equipment on the wrong car, accidentally, but by the time they had realized the issue... it was too late- the customer was already out the door... wish I only had that problem to deal with (stoked the 81 didn't have to deal with any of that).
1985 300D
post #9 of 11 (permalink) Old 09-18-2009, 10:26 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
What is this emissions test you speak of?
Nutz 4 Benz is offline
post #10 of 11 (permalink) Old 09-19-2009, 06:52 AM Thread Starter
gf70sShow's Avatar
I don't know about many other states, but in New York all cars built after 81? (somebody on here must know this number for sure) have to be put through an emissions test to pass the state inspection. Cars built within the recent past are waived from the test and for all I know diesels are exempt as well. Im a business guy, not a mechanic, but I read the inspection list a few months ago and only remember some of it. New York is a pain- the brewer at the place I would at is from Michigan, he just has to send them money every year (from NY) to keep his car on the road!
1985 300D
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Failed Inspection 190E Dee W201 190-Class 10 04-01-2009 08:32 PM
inspection failed due to unbalanced front brakes GGR Vintage Mercedes-Benz 5 11-05-2008 10:08 AM
Failed inspection AlanS W124 E,CE,D,TD Class 3 06-26-2008 06:34 AM
Failed inspection due to "bad" ball joints at 32K saxmanjack R170 SLK-Class 9 06-11-2007 03:46 PM
Need Help-Failed NJ Inspection Feyms@aol.com R129 SL-Class 3 11-27-2004 09:30 AM
