Flappy 240d Vacuum Governor - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-02-2009, 02:56 AM Thread Starter
Date registered: Apr 2009
Vehicle: 1982 200D ex German with 240D engine
Question Flappy 240d Vacuum Governor
Hi Everyone,
The Vacuum Butterfly in the intake manifold of my 240D is free to flap open and closed of its own accord when the engine is off. Is this normal?
I am new to Diesels but sort of expected it to have a spring attached so it returned to one position.
Any help would be much appreciated as I am trying to track down some running issues.
NZDIESEL is offline
post #2 of 3 (permalink) Old 08-02-2009, 03:13 AM
~BANNED~
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
There is a rod that should attach it to the accelerator linkage.
Instead, remove the butterfly entirely and unplug the switchover valve on the right front fender.
Remove the two flatblade screws seen in the center of the valve, turn the valve and pull the butterfly out of the slot.
This is the switch.
Name:	240D EGR butterfly DSC00077.jpg
ID:	252310   Click image for larger version
Name:	240D EGR fender valve.jpg
Zedd is offline
post #3 of 3 (permalink) Old 08-02-2009, 04:04 AM Thread Starter
Wow many thanks for that!
Its super helpful people like you whom save the rest of us a lot of time and hassle re-inventing the wheel!
So just to clarify given that my car is ex German LHD and has no emmision gear on it if I disconnedted the butterfly as you recommend I wouldnt even need a linkage going over the rocker cover?
Appologies if I have got this wrong!
Thanks again!
NZDIESEL is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Flappy paddles retrofit Helen Jones R171 SLK-Class 2 02-22-2009 08:33 AM
    Vacuum Gremlins- '78 240D christophesteele W123 E,CE,D,CD,TD,TE Class 0 06-25-2008 03:36 PM
    Flappy Paddle Mystery... kenzed R171 SLK-Class 4 01-05-2007 02:42 PM
    240d Vacuum replace Storx W123 E,CE,D,CD,TD,TE Class 8 06-13-2006 02:09 AM
    '83 240D vacuum diagrams RoyH W123 E,CE,D,CD,TD,TE Class 4 01-04-2005 07:10 PM
