Best injector cleaner additive for diesel engines? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-22-2009, 03:54 PM Thread Starter
BenzEagle's Avatar
Date registered: Jun 2009
Vehicle: 2003 E320
Quoted: 62 Post(s)
What is generally the best fuel additive to clean injectors?
I used a Redline product, which didn't seem to be good.
I also used putting automatic transmission fluid (dextron/metron 5) into the fuel filter to clean the injectors this way. Is this a good thing to do, or does it endanger the engine if you do it too often (I already did it twice).
Until I get an appointment for injection pump timing/ALA adjustment I'd like to make my injectors as clean as they can get. I have improved the black smoke issue, but I'd like to improve it more, and then get the timing adjustments.
Thanks!
BenzEagle is online now
post #2 of 11 (permalink) Old 06-22-2009, 04:18 PM
MBZ300CD's Avatar
Date registered: Oct 2004
Vehicle: 1984 300CD, 1983 240TD Euro
Quoted: 61 Post(s)
Don't want to start any trouble here but you may want to check out Lubro Moly "Diesel Purge". I use it before I change my fuel filters at 30,00 mile intervals.
Gary
1984 300CD, Exterior Code # DB877 Petrol - Blue/Green Interior Code #155 MB-Tex Creme
"Even more attractive than this coupe's classic lines are it's classic over-the-road capabilities".
Mercedes-Benz of North America 1984 range brochure
SR 395 @ Mono Lake, CA
MBZ300CD is offline
post #3 of 11 (permalink) Old 06-22-2009, 04:48 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
An additive won't be able to do that. They only way to reach that goal is to have your injectors removed, then disassembled and cleaned, reassembled and pop tested.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #4 of 11 (permalink) Old 06-22-2009, 05:54 PM
POS
POS's Avatar
Date registered: Oct 2005
Vehicle: 1966 250SE Cab, 1989 500SEL euro
Quoted: 26 Post(s)
Yeah, I highly recommend the diesel purge - you don't have to use anything special, just something good. I did this procedure on my old '82 with two cans of SeaFoam, and the results were significant. Simply put, you take the intake line to the injector and put it in the can, and you take the exit from the filter and put it in an empty container - then run the car for 10-15 mins on 100% SeaFoam. It's worth it bigtime.
- Brian
1989 500SEL ECE
1966 Mercedes 250SE Cabriolet
1958 BMW Isetta 600
POS is offline
post #5 of 11 (permalink) Old 06-22-2009, 06:22 PM Thread Starter
BenzEagle's Avatar
Vehicle: 2003 E320
Quoted: 62 Post(s)
Thanks for your input.
I'll get Lubro Moly's "Diesel Purge".
I'll check out "SeaFoam" engine cleaner. There are a few clips on YouTube.
Burning automatic transmission fluid, nobody has commented to this so far. Any results?
Disassembly and cleaning and pop-testing would definitely be the best (but I'd probably put in new injector tips), but at this time I have to go the budget route.
post #6 of 11 (permalink) Old 06-22-2009, 06:40 PM
~BANNED~
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
Don't. Its nothing more than lantern oil and actually does nothing beneficial.
Even worse. Its harmful, not beneficial. ATF is not a fuel and shouldn't be anywhere near your injection system.
So, spend $40 on useless snake oil or $75 to actually get them clean.
If you use quality fuel from a good source (a high traffic truck stop) then those snake oil cans wouldn't even be considered. If you use cr@p fuel from the cheapest gas station you come across then you'll be spending money to get your injectors cleaned every few years.
If your injectors are over 100k miles old they need to be removed and tested anyways.
Zedd is offline
post #7 of 11 (permalink) Old 06-22-2009, 06:50 PM Thread Starter
BenzEagle's Avatar
Vehicle: 2003 E320
Quoted: 62 Post(s)
Thanks for this.
I didn't know that cleaning the injectors was only 75$ (hopefully not per injector).
The injectors worked well and weren't noisy or nailing until I had a vacuum pump breakdown. The resulting smoke must have really clogged them. I wanted to readjust injector pump timing anyway, so I can do both in one.
And no more transmission fluid into the fuel filter.
PS: you didn't mention SeaFoam. I found quite a lot on the web and people seem to like it.
post #8 of 11 (permalink) Old 06-22-2009, 07:29 PM
~BANNED~
Zedd's Avatar
Most places charge about $15/injector to clean and test.
The vacuum pump can't cause smoke.
Right, clean fuel only.
Don't pour the fuel from the old filter into the new one. I've seen some people do that and it makes changing the filter pointless.
Is snake oil like every other "cleaner" and "performance booster" on car part store shelves.
Zedd is offline
post #9 of 11 (permalink) Old 06-22-2009, 08:48 PM Thread Starter
BenzEagle's Avatar
Vehicle: 2003 E320
Quoted: 62 Post(s)
It was the breaking down of the vacuum pump that caused wild smoke.
No idea what was exactly happening. Even with the broken vacuum pump and the smoke the engine sounded OK (minus the rattle of the broken vacuum pump, which still produced vacuum).
When I got the car back from the mechanic, it was nailing hard, had no power, smoked like a wild west iron horse. It has improved, but power is still bad.
No idea what caused the injectors to clog up that quickly. I'll go for a cleaning first, and if this doesn't help, for a timing adjustment of the injector pump. (The mechanic took the timing chain off. No idea what he could have messed up).
Your advice, Zedd, is very much appreciated. Especially with the mechanical cleaning of the injectors and the pop testing.
post #10 of 11 (permalink) Old 06-22-2009, 08:51 PM
~BANNED~
Zedd's Avatar
The vacuum pump can't cause smoking. It doesn't have any influence over the engine except to turn it off.
Zedd is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Fuel Injector Cleaner (gas additive)? TheJimbo R170 SLK-Class 31 04-13-2015 10:19 AM
    Fuel Injector Cleaner? Old Otto W210 E-Class 17 04-05-2008 06:45 PM
    Should I use injector cleaner? blue280ce W123 E,CE,D,CD,TD,TE Class 2 10-21-2004 05:15 PM
    OT Q: Are diesel engines more reliable than gasoline engines, and if so why? Thnx. Cap R170 SLK-Class 2 11-13-2002 05:44 AM
    Nate, the fuel additive is Red Line Diesel additive- imrov. 30 to 33 mpg Guest (MBNZ) W201 190-Class 2 02-16-2002 10:19 AM
