Antenna & Sunroof Repair - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-19-2009, 01:49 PM Thread Starter
Date registered: May 2009
I have a '85 300D and need some advice on a couple of things...
1.) The antenna will only raise halfway.
2.) Sunroof opens fine but has a loud groan when I try to close it. It will not close without help
Any suggestions on fixing these issues?
scudderb is offline
post #2 of 6 (permalink) Old 05-19-2009, 01:58 PM
gf70sShow's Avatar
Date registered: Sep 2008
Vehicle: 1985 300D, 1981 300TD
The motors for those antennae are pretty expensive, the trick with mine was: get it shimmied up to full mast and disconnect it so that it won't come down... the bad part of that is, as you may have guessed, it won't come down. I actually have an 85 300D that is possibly meeting its maker this summer and it may be putting its sunroof motor on the auction block...
1981 300TD "The Badger"
1985 300D
If you get confused, listen to the music play.
gf70sShow is offline
post #3 of 6 (permalink) Old 05-19-2009, 06:51 PM
sean46953's Avatar
Date registered: Mar 2009
Vehicle: 1985 Mercedes-Benz 300D
Send a message via Yahoo to sean46953
As for the sunroof, you may try to "clean" (just wipe clean) the track, then re grease. I used a combination of a light oil (3-in-1) and petroleum jelly. Before I did this, it groaned loudly when opening and closing. Now it's silent and moves freely. You my also take a look at a grease tube that is hooked to the back of the sliding roof's motor and runes behind the plastic trunk panel on the drivers side. It should just slide up and off the motor. You may check to see that it is still straight and isn't dented or pinched anywhere but at the end. My antenna mast was also being super funny with me, but some one before me installed a new motor in the car. I found that they are picky with their ground and need a perfect ground connection. Also, my connectors were a little gummed up. Now it works ok...has not problem going up, but going down doesn't happen too often. lol Hope this helps! Good luck!
sean46953 is offline
post #4 of 6 (permalink) Old 05-19-2009, 08:20 PM
DoktorNo's Avatar
Date registered: Jul 2006
My 82 240D had a switch that would select partial or full extension of the antenna. If it is jamming, then replace the mast before the motor is damaged. It is easy to do and the mast is around $30. If I look at a used Mercedes, and the antenna is rigged up all the way or some POS rubber replacement has been installed, I immediately suspect the care of the vehicle.
1971 300SEL 6.3
1985 280TE 5spd
1986 190E 2.3-16V
1986 300E 5spd 24hoursoflemons car.
DoktorNo is offline
post #5 of 6 (permalink) Old 05-19-2009, 09:49 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 207 Post(s)
The standard action of the antenna is to go half way when the radio is turned on. If it does not extend fully, something can be wrong inside the assembly. Could be the mast, or the gearing inside (plastics breaking).
MBeige is offline
post #6 of 6 (permalink) Old 05-20-2009, 08:18 AM
300DT85's Avatar
Date registered: Apr 2009
Vehicle: 300k miles..
300DT85 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
sunroof repair Roadhouse_wannabe W126 S,SE,SEC,SEL,SD,SDL Class 21 09-11-2012 05:14 PM
w203 TV antenna amp problem & part numbers & vin/chassis nos perdikoula888 Audio & Telematics Forum 1 09-28-2010 09:16 PM
91 300 se sunroof parts & repair Rob Weamer W126 S,SE,SEC,SEL,SD,SDL Class 3 05-14-2010 01:26 AM
Brabus antenna & Antenna base question thanosSLK R171 SLK-Class 17 12-01-2006 10:26 AM
Sunroof repair Help? Sandro N W210 E-Class 2 02-16-2005 06:19 PM
