can't open hood... - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 07-25-2008, 06:36 AM Thread Starter
Date registered: Jul 2007
can't open hood...
i tried to pop the hood yesterday and the release inside the car didn't work. the cable still seems to be attached to the handle/mechanism, but there was no resistance when i pulled it and the hood remained firmly shut so i couldn't use the latch which comes through the hood. this is a particular problem since i have a vacuum problem at present and need to open the hood to shut off the car - i know, i need to deal with this, pronto, too.
any suggestions?
jason
navakahn is offline
post #2 of 18 (permalink) Old 07-25-2008, 01:42 PM
Date registered: Jan 2007
Vehicle: Elvira '84 300CD 238K miles, '87 300TD 175K, Sarah Jane '74 TR6 78K, OBK #27
Make a small hook in the end of a coat hanger, then slip it through the grill and grab the little plastic handle that normally pops out through the grill when you pull the hood latch, that should open it
Land of the Free
Because of the Brave
123Guy is offline
post #3 of 18 (permalink) Old 07-25-2008, 02:22 PM
frans-c's Avatar
Vehicle: 2000 W202 Mercedes-Benz C250 Turbodiesel
Quoted: 22 Post(s)
Take a look here: http://www.benzworld.org/forums/w123...ble-broke.html
F R A N S
2000 Mercedes-Benz C250 Turbodiesel
frans-c is offline
post #4 of 18 (permalink) Old 07-27-2008, 09:36 AM Thread Starter
not sure i was clear...
frans,
thanks, i'd seen that thread, but i think that one addresses the problem if one can release the hood from inside the car but not open it from outside it. or maybe i'm not understanding things clearly.
likewise, 123guy, i've pulled on the plastic tab, but it won't open. the hood is still firmly shut and pulling on the tab won't seem to release it.
what i'm hoping to do is to get to the point where the hood releases so that i can fish for the plastic tab and open it then. does that make sense?
forgive me if i've misunderstood something here, i'm just trying to clarify in case i wasn't clear.
thanks,
jason
navakahn is offline
post #5 of 18 (permalink) Old 07-27-2008, 10:14 AM
frans-c's Avatar
Quoted: 22 Post(s)
Jason, I had exactly the same problem that you had - no matter how hard I pulled at the hood-release inside the car, it wouldn't pop the hood. That's how I discovered the screwdriver method. Don't bother pulling the hood tab; it won't work.
Pity I can't help you in person ...
F R A N S
frans-c is offline
post #6 of 18 (permalink) Old 07-27-2008, 11:21 AM Thread Starter
thanks
thanks, frans, i'll get on it this afternoon.
i appreciate the help,
jason
navakahn is offline
post #7 of 18 (permalink) Old 02-14-2010, 07:29 AM
Date registered: Feb 2010
Vehicle: 91' W124 300E
Cant see the thing you show on the pictures in the other thread.
Is it behind the plastic located next to the hood tab mechanisme?
I have a flat battery and my loved W123 is my only car so I am now stuck...
skolms123 is offline
post #8 of 18 (permalink) Old 02-14-2010, 07:56 AM
hheynow's Avatar
Date registered: Aug 2008
Vehicle: 1984 €uro 300D NA
Is it behind the plastic located next to the hood tab mechanism?
Unfortunately it is. That's our Mercedes anti theft device.
1984 Mercedes €uro 300D NA - 178K miles
Thistle Green Metallic - Custom VO two tank
1997 Ford F-350 7.3L Powerstroke turbo diesel - Plant Drive VO Kit
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #9 of 18 (permalink) Old 02-14-2010, 09:38 AM
And the only way is to destroy the plastic cover?
No way! I am not doing anything that will hurt my W123, hehe
Any other way? Mercedes had to make a way around this problem.
post #10 of 18 (permalink) Old 02-14-2010, 10:40 AM
hheynow's Avatar
If you have enough slack on the cable can you grip the wire with vice-grips at the lever and pull?
BTW the Mercedes Gods on this forum will NOT look down upon you if you remove that plastic cover. Here's what it looks like front and rear.
ID:	290887   Click image for larger version
hheynow is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    Ok so how do I open the hood? ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 32 06-19-2008 11:07 PM
    Hood can not open ec1012 R129 SL-Class 2 08-28-2007 09:25 PM
    can't open hood youngbenzlover W210 E-Class 0 08-28-2007 02:59 PM
    Can't open Hood..help! IceBlue_1980_300TD W123 E,CE,D,CD,TD,TE Class 6 04-13-2006 11:14 PM
    hood won't open help ! kmichael30 W123 E,CE,D,CD,TD,TE Class 3 10-31-2004 08:04 AM
