» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-14-2008, 09:49 AM   #31 (permalink)
81240D's Avatar
Date registered: Jan 2007
Vehicle: 1981 240D, 2006 S 430 4 Matic, 2007 GL 450 4 Matic
Axle
I had the some problem with 1981 240D . it was the CV Joint / half shaft
. You probably have to replace it .
81240D is offline   Reply With Quote
Old 05-14-2008, 10:20 AM   #32 (permalink)
torkq's Avatar
Date registered: Dec 2007
Vehicle: 1984 Mercedes-Benz 300DT; 1980 Mercedes-Benz 300SD
I think for now it just needed grease, I haven't heard even a whimper from it since I bathed it in grease, hopefully it'll give me atleast a few more months, while I save up for rebuilt (maybe even new?) axles
'84 300DT 314k (w123);
'80 300SD (w116), two-tank fuel system
torkq is offline   Reply With Quote
Old 05-14-2008, 07:06 PM   #33 (permalink)
Benzoid123's Avatar
Vehicle: 1982 Mercedes 300TD wagon
Yeah when my half shaft died on my 84 300D it sounded just like that. Mine made no noise until they heated up when on the freeway. It sounded like a jackhammer in the trunk. If you plan to keep the car for a while, just buy a new one (or two since as my dad used to say "Sh*t breaks in pairs") from autohausaz.com. They go for like $300-$330 each but they won't give you anymore problems. I did a lot of freeway trips on that car so I wanted a set that wouldn't let me down in the middle of nowhere.
Benzoid123 is offline   Reply With Quote
Old 05-15-2008, 03:40 AM   #34 (permalink)
Date registered: Mar 2007
Vehicle: 1985 W123 230EM
Send a message via Skype™ to RSK_W123_230E
Not the wheel bearing
The sound on your wave file is linked to rotational frequency, a wheel bearing would be a constant grinding and change if you move the steering from left to right, thereby loading the bearing. One of your half-shaft joints has gone which explains the clunking frequency changing with speed.
1985 W123 230E Manual, 210,450 km / 131,531 miles
RSK_W123_230E is offline   Reply With Quote
Clanking Noise on 94 C280 Raxhi W202 C-Class 0 03-31-2008 09:42 AM
clanking / knocking noise orangebang49 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-28-2006 06:01 AM
Clanking noise from rear of 300TE: What's the source? ron in sc W124 E,CE,D,TD Class 2 01-22-2006 12:32 PM
04 ml500 clanking noise pointman W163 M-Class 9 03-25-2005 11:43 AM
Clanking noise SteveL R170 SLK Class 3 03-22-2001 07:23 AM
