finally,,W123 service manual download link - Mercedes-Benz Forum
post #1 of 41 (permalink) Old 04-21-2008, 11:52 AM Thread Starter
harpreet928's Avatar
Date registered: Nov 2006
Vehicle: mercedes benz 300d
Quoted: 2 Post(s)
Send a message via Yahoo to harpreet928
hey guys
i think many of us wanted to have these kind of notes regarding the servicing and maintainability of our w123.
i was just browsing over internet for w123 and i came acroos a site named as ozbenz.net,,, there i find this link so i want to share it among everybody.
Auto service & repair manuals: Mercedes Model Year 1981-1993 (107, 123, 124, 126, 129, 140, 201 models) Maintenance Manual
Mercedes - Series 107, 123, 124, 126, 129, 140, 201 (1981-1993) - Maintenance Manual.zip..
it has these topics in it...
inspecting component condition
Inspecting condition of lines and hoses
Inspecting components, lines and hoses
Suspension and body structure inspection
Water leakage and corrosion inspection
Engine oil and filter change
Adjusting valve clearance
Checking valve clearance
Checking and adjusting idle speed
Checking injection timing
Adjusting injection timing
Replacing fuel filter
Replacing fuel prefilter
Cleaning metal reinforced air filter element
Replacing air filter element
Replacing air filter elements
Checking condition and tension of V-belts
Inspecting poly V-belt
Checking intake & exhaust manifold seating
Replacing oxygen sensor
Check spark plugs, replace if necessary
Replacing spark plugs
Checking coolant level & antifreeze protection
Checking cooling & heating system
Replacing coolant
Adjust engine stop, retorque engine mount bolts
Adjust engine stop
Checking clutch disk for wear
Manual transmission oil change
Manualo transmission, checking & correcting oil level
Automatic transmission fluid and filter change
Automatic transmission, checking & correcting fluid level
Transfer case fluid change
Transfer case, checking & correcting fluid level
Clutch system, checking & correcting fluid level
Clutch system, inspect
Inspecting & lubricating throttle linkage
Checking and adjusting idle speed adjuster
Level control, ADS, ASD, 4MATIC, fluid level
Inspecting self-leveling suspension
Front axle, checking & correcting oil level
Checking front axle ball joints
Checking ball joints using special tool
Rear axle oil change
Rear axle, checking & correcting oil level
Rear axle mount, adjusting limiting stop
Inspecting & rotating wheels
Inspecting tires
Correcting tire pressure
Tightening wheel bolts
Inspecting drive shaft flexible coupling
Checking brake fluid level
Inspecting brake lines
Checking brake pads & disk thickness
Inspecting & cleaning brake disks
Inspecting parking brake cable
Adjusting parking brake
Replacing brake fluid
Brake test, parking brake check
Check power steering fluid level
Checking steering play
Retightening steering bolts
Checking fuel system condition
Retightening exhaust flange
Retightening exhaust system connections
Checking & correcting battery fluid level
Checking warning & indicator lamps
Cleaning water drains
Removing and installing engine compartment lower panel
Lubricating door hinges
Lubricating door locks
Hydraulic top, checking & correcting fluid level
Sunroof, clean & grease rails
Soft top, checking locking tabs
Checking & correcting windshield washer fluid level
Cleaning cassete deck tone head
Cleaning antenna mast
Headlamp & exterior lamp inspection
Windshield & headlamp wiper & washer inspection
Replacing windshield wiper blade
Checking & correcting AC refrigerant charge
Replacing dust filter for heating & ventilation
Replacing active charcoal filter
Replacing recirculating air filter
Lubricating folding side mirror
Lubricating hood
Inspecting safety belts
Backrest lock - check operation
Removing & installing lower noise encapsulation panels
Checking body for paint damage
harpreet928 is offline
post #2 of 41 (permalink) Old 04-21-2008, 11:54 AM Thread Starter
Quoted: 2 Post(s)
post #3 of 41 (permalink) Old 04-21-2008, 11:57 AM
vipercrazy's Avatar
Date registered: Jan 2007
Vehicle: EURO 280CE
Send a message via AIM to vipercrazy
how do you browse through it quickly?, it seems rather large ill stick to my online one
for sale: Car Domain 80 EURO 280CE M110.984 english red, white cloth interior 194k
daily driver: 93 toyota MR2, black 5spd non-turbo, may just have to remedy that
mopar: 62 chrysler newport 4DR white 361 V8, 36k miles
vipercrazy is offline
post #4 of 41 (permalink) Old 04-21-2008, 02:05 PM
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro found dead on Ebay
I am with you viper but am keeping a copy as a backup in case the internet one disappears.
cheapold280ce is offline
post #5 of 41 (permalink) Old 04-21-2008, 04:42 PM
mercedesbenz911's Avatar
Date registered: Oct 2007
Quoted: 4 Post(s)
What internet one are you talking about? Link?
1982 280SL - Petrol Green/Palamino
1984 300CD - Signal Red/Palamino?
1994 E420 - Brilliant Silver/Gray
1995 E320 wagon - Brilliant Silver/Gray
mercedesbenz911 is offline
post #6 of 41 (permalink) Old 04-21-2008, 05:40 PM
vipercrazy's Avatar
Vehicle: EURO 280CE
ive came across many, but here are some i have saved
Model 123 - M110 Maintenance Manuals
MB.AUTO.PL - Silnik M110
i hope no one floods these and they go down
post #7 of 41 (permalink) Old 04-21-2008, 11:50 PM Thread Starter
Quoted: 2 Post(s)
i just use winrar software to open that zip file and files are runned by adobe application PDF simple,,, why does it seems to so large files when we have it in one zip file
post #8 of 41 (permalink) Old 04-22-2008, 02:00 AM
Quoted: 4 Post(s)
Thank you for the link to the zip Harpreet
@vipercrazy
I can use those for my 280SL with M110 I guess, lol. Do you have any for the 617?
post #9 of 41 (permalink) Old 04-22-2008, 05:48 AM
~BANNED~
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
Finally? I've had them available for over 6 months now.
Demonoid.com - Mercedes W123 and OM617 factory service manual
Zedd is offline
post #10 of 41 (permalink) Old 04-22-2008, 11:40 AM Thread Starter
Quoted: 2 Post(s)
here another link for CD but for $250,,,,
does anybody have this cd??
to share it hereAustralia's leading Mercedes-Benz website
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    SLK R170 repair manual cd download link!! Black98SLK230 R170 SLK-Class 72 02-04-2016 09:08 AM
    98 SLK GENERAL SERVICE MANUAL CD DOWNLOAD zofitness R170 SLK-Class 16 07-28-2010 09:27 AM
    Download Link for a REAL Technical SLK Manual???? SithPitt R170 SLK-Class 8 11-28-2006 04:56 PM
    Can someone post the link to the online service manual? rjb190e W201 190-Class 8 08-23-2006 11:04 PM
    For sale w123 service manual Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 12 04-21-2002 05:22 PM
