Testing Vacuum Pods - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 04-12-2008, 02:32 PM Thread Starter
Date registered: Aug 2007
Vehicle: 82 300D
Testing Vacuum Pods
I've been reading alot about how to replace the Vacuum Pods in my HVAC system for an 82 300D. My HVAC system currently always puts air out the defrost and side vents no matter what setting. How do I determine which pods (if any) need to be replaced without actually pulling the dash to replace them?
tgoodwin is offline
post #2 of 12 (permalink) Old 04-12-2008, 06:08 PM
to loss's Avatar
Date registered: Nov 2005
Vehicle: 1982 300TDT 150,000 miles 1985 380SE 130,000 miles 1991 560SEL 81,000 miles (a/k/a the nightmare)
You'd do best by pulling the dash, and getting replacement diaphragms for your pods through George Murphy at Performance Analysis Company in Tn... (He supplies a sheet that outlines the way to test the pods once they are installed, and the same procedure could probably be used to troubleshoot the vacuum system... but by the description of your problem, sounds like you'd be better served taking the dash out, as I believe you'll find more systemic problems... also, if sometimes it's best to change all relevant and known failure points of the system (within reason and cost effectiveness) at this stage of the game).
While you've got the dash out, you can change all of the rubber bits that will fail sooner or later, and check your vacuum switchover valves and replace. I don't think there is any easy way to diagnose your problem.
"I don't think it's nice, you laughin'. You see, my mule don't like people laughing. He gets the crazy idea you're laughing at him. Now if you apologize, like I know you're going to, I might convince him that you really didn't mean it."
"I love the smell of diesel in the morning... smells like... like victory"
to loss is offline
post #3 of 12 (permalink) Old 04-13-2008, 04:56 AM
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
Quoted: 15 Post(s)
The only pod that you can not easily get to without pulling the dash is the #3 pod that controls the center vents. You can test that one without pulling the dash as well.
http://www.benzworld.org/forums/w123...m-control.html
But if that one is your problem, removing the dash isn't impossible.
Gregs300CD is offline
post #4 of 12 (permalink) Old 04-13-2008, 06:56 AM
Date registered: Jan 2007
It is also possible to change the center vent pod with out pulling the dash.
I just did mine and all it takes is patience and small hands
Tony
tgomes is offline
post #5 of 12 (permalink) Old 04-13-2008, 07:52 AM
Gregs300CD's Avatar
Vehicle: 1982 300CD
Quoted: 15 Post(s)
I don't think I could do it. Something would break. Not only are my hands way too big to get in there, but frustration level with the dash off is about 80% threshold as it is. I was trying to be careful, but still snapped one of the pegs and broke one of the spring locks in half. I found a suitable replacement for the spring lock at the hardware store and I was replacing the entire pod, so no big deal. Still a royal pain.
post #6 of 12 (permalink) Old 04-13-2008, 09:13 AM Thread Starter
Vehicle: 82 300D
The center pod is the one in the dead center of the dash up close to the fire-wall?
tgoodwin is offline
post #7 of 12 (permalink) Old 04-13-2008, 11:27 AM
Gregs300CD's Avatar
Vehicle: 1982 300CD
Quoted: 15 Post(s)
Read the post: http://www.benzworld.org/forums/w123...m-control.html
You'll see where they're all located.
post #8 of 12 (permalink) Old 04-13-2008, 12:01 PM
Date registered: Jun 2004
Vehicle: 1980 300D
The center vent vacuum actuator is up on top, centered beneath the dash by the air flap it actuates. By removing the circular center vent housings - they unscrew easily from retaining rings inside dash holding them in place - it is possible, though tedious, to replace diaphragm in actuator without removing dash, helped by a third person with small hands reaching through center vent openings to hold things in place. More simple than removing dash, dexterity and patience required. George Murphy's replacement diaphragms work very well, once diaphragms are replaced actuators work flawlessly. New replacement actuators often have different mounting systems than actuators in place - check and double check mounts.
DOUGLAS MARTIN is offline
post #9 of 12 (permalink) Old 04-13-2008, 10:08 PM
FratBoy's Avatar
Date registered: Jun 2006
Vehicle: 1980 280CE; 1982 300CD
Quoted: 26 Post(s)
Removing the glove box (easy to do) will also yield access to the center vent actuator. This method may be more graceful than removing the center vents, IMHO...
FB
The Inventory:
1982 300CD 162k (5 speed coming soon)
Those Not so Lucky:
1982 300SD 205k with SBC 350 + TH350
1979 230C Euro 4 Speed 161k, more
1980 280CE US with Euro M110 + 4 speed 126k, more pics
1980 280CE Euro 4 speed 101k
1983 280E Euro 5 speed (parts only)
1980 280E Euro 4 speed 165k
1985 500SEC US (shmoove)
1982 300D US 4 speed
1978 300CD US
1979 300D US
FratBoy is online now
post #10 of 12 (permalink) Old 04-14-2008, 03:43 PM Thread Starter
Vehicle: 82 300D
I can't find where to buy the replacement diaphragms. Can anyone help me with a link?
tgoodwin is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
HVAC Vacuum Pods from Autohaus or from Dealer? to loss W126 S,SE,SEC,SEL,SD,SDL Class 5 12-10-2007 11:03 AM
ac blower things to check before suspecting vacuum pods St3ve W124 E,CE,D,TD Class 0 11-10-2006 01:11 PM
Need gauge pods DynamicS R171 SLK-Class 3 07-19-2006 06:00 PM
Climate control vacuum pods - repair story Niloc W123 E,CE,D,CD,TD,TE Class 2 01-17-2006 12:12 PM
HVAC vacuum pods - part numbers? special tools? kggkgg W124 E,CE,D,TD Class 0 02-26-2005 12:07 PM
