Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 03-18-2008, 12:33 PM   #1 (permalink)
asghilo's Avatar
Date registered: Jan 2008
Vehicle: 1981 300cd, 1981 300sd
300cd tranny fit a 240d?
Does this swap bolt up easy? I have an '81 300cd parts car with a good tranny and i'd like to swap it into my '82 240d. The thing I was wondering is are they the same size or is the 300cd tranny longer/shorter being that it's a 2dr coupe or is the difference of length made up in the driveshaft?
if it ain't broken, i don't own it.
asghilo is offline   Reply With Quote
Old 03-18-2008, 01:26 PM   #2 (permalink)
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 80 240D 3.0VNTi
They have significantly different shifting controls. Compare the part numbers on the transmissions (right side, above the the pan).
1980 240D 3.0VNT 222k miles
Modifications (Link): OM617.952, 4-speed manual, GT2256V VNT turbo, W115 300D intake, ALDA/EGR/rack limiter removed, 3.46 diff, 15mm rear sway bar, Amsoil bypass oil filter, Mobil1 5W-40 synthetic oil.
"You call parking a supersonic jet in front of a titty-bar 'inconspicuous'?"
youtube.com/Turbo617
http://superturbodiesel.com
Zedd is offline   Reply With Quote
Old 03-18-2008, 01:27 PM   #3 (permalink)
KCM
Date registered: Jun 2004
Driveshafts are different for sure. Trannys are the same length and should swap. One problem would be in the vacuum controls, or lack of on early W123's. Is your 300CD a turbo? Turbo cars had a different transmission, but I believe they should still bolt up. Not sure if the turbos had a different vacuum system though.
KCM is offline   Reply With Quote
Old 03-18-2008, 10:42 PM   #4 (permalink)
mbkomfort's Avatar
Vehicle: MB 230TE 84- MB 280SE 80-
the tranny can be used, yes.
the problem is adjustment of the shift controls. The diesels have 4 different control systems that i have seen. 1: only rod controlled 2: only vakuum controlled 3: rod and vakuum controlled 4: wire and vakuum controlled.
You have both trannys, so you can check if they have the same controls..
mbkomfort is offline   Reply With Quote
WTB: 1980's W123 Diesel (300D, 300CD, 240D, etc) in Los Angeles salamandyr For Sale, Trade & Wanted Items 0 01-11-2007 09:09 PM
Will 1979 300CD Seats Fit in an 83 300D ? panamacolin W123 E,CE,D,CD,TD,TE Class 5 09-01-2006 11:39 PM
83 Benz 240D,300D,300CD Owners Manual 4 Sale digsand W126 S,SE,SEC,SEL,SD,SDL Class 0 02-27-2004 02:47 PM
will 18's fit my 300CD? chucky10 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-18-2003 07:12 AM
will 18's or 19's fit my 300CD? chucky10 W123 E,CE,D,CD,TD,TE Class 0 12-12-2003 01:24 PM
