» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 02-13-2008, 12:48 AM   #11 (permalink)
mercedesbenz911's Avatar
Date registered: Oct 2007
Vehicle: 85 300D, 82 280SL, 86 230E
From the back by the tank. It has 275,000 mi on it.
mercedesbenz911
mercedesbenz911 is offline   Reply With Quote
Old 02-13-2008, 01:24 AM   #12 (permalink)
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
Then the problem is from age, road debris/salt/mag chloride and lack of preventive maintenance.
That tube is 23 years old, I'm amazed it (and many others) last as long as it does. Rubber naturally gets old and brittle, that hose should have been changed a decade ago. ULSD had nothing to do with its failure.
youtube.com/Turbo617
Zedd is offline   Reply With Quote
Old 02-13-2008, 10:59 AM   #13 (permalink)
rockwool's Avatar
Date registered: Dec 2007
Originally Posted by torkq View Post
it all depends on what type of biodiesel you choose to use, there are many types, b5 through b100, b100 being 100% biodiesel,
Is diesel with 5% methylester in it considered as biodiesel in the US?!!
mb911, if you haven't changed all rubber (fuel lines, washers etc) that comes in contact with diesel to new ones, or preferably ones made of Vitron, you shouldn't go B100. Once you've done this, AND changed all the fuel filters to fresh ones, you could slowly step up the percentage, from 10% the first time, by 10% for each full tank you fill.
This being so because biodiesel is a, or works as a, solvant on rubber material and all the soot and shit that has been built into the walls of your engine. Because of this, your newly changed fuel filters will soon clog, so always keep a spair couple and nessesary tools (a screwdriver) in your car.
But to be on the sertain side, you should double check my info on how fast you can rase that percentage on a biodiesel forum.
But remember, 20% will do enourmous differances for the biodegradability of your petroleum diesel. Even 10% will do that and you don't need to do fuck all with your existing lines, if they are in normal condition. If they're not, you need to change them every once in a while anyways..
Sad thing is that a lot of the biodiesel produced today is of the "dirty" kind, a lot of it in the US is. With dirty means that it's total production line causes more, or close to it, CO than regular class 1 diesel. But check which places sells clean biodiesel at a specific forum for it.
SVO/WVO is better than biodiesel as it doesn't have any chemicals mixed in it to make it less viscuose. I know WVO people aren't too excited about biodiesel. Why and what the benefits are, you should ask them. I know Greasecar has a big forum, also check Frybrid.
1986 200T - 459,XXX km - (881) Silberdistel/Thistel Green - (056) Dunkelolive
rockwool is offline   Reply With Quote
Old 02-13-2008, 01:24 PM   #14 (permalink)
It is leaking from the rear near the tank. I can see some residue on the bottom of the exhaust.
Old 02-13-2008, 01:27 PM   #15 (permalink)
Oops, sorry for repost.
Old 02-13-2008, 01:29 PM   #16 (permalink)
I was thinking of SVO more because I can get it cheap. What would be some pros and cons of it?
Old 02-13-2008, 03:02 PM   #17 (permalink)
rockwool's Avatar
The pros are that you don't have to filter it, settle it for a few days before you can use it, no slobbing while collecting or fixing it at home, no chance of it ruining your engine (with time) because of sloppy filtration/bad choice of source.
The cons are more abstract, as it won't affect your daily life and probabaly not your holliday eather, and is more on a philosophical level as you are still exploiting the land instead of using up a waste product, yes it's a renewable source but if we want this place not to go to hell just because of our generation (and a few before and after) we have to start using all waste products that we can.
Another thing is the signal you partly give when you purchase a product of nature, as SVO is closly related to biodiesel in that sence, is by saying to landowners around the world that they should cut our lungs out and feed it to us as food. We try to do good but we're still part of the problem. Another problem, but still a problem.
Finaly, SVO usage is contributing to is to increase malnutrition and starvation in this world. People in third world countries have already noticed the increased prices of agricultural products in their countries because of the increased demand of it that has come from the north. A demand that actually is increasing fast as this ethanol/biodiesel thing is pretty new and yet only a small percentage of our car fleet can use it.
We're all creatures of comfort, we all love to run the easiest way (even if the're other ways that are only marginally more troublesome) and we all have trouble understanding situations that we haven't lived our selves. I'm glad that I can't afford a nice rust free example of a diesel W123 yet (they're practicly non existent i Sweden due to stupid and unfair non diesel friendly laws) as I would have to do the same choises you're facing now.
Old 02-13-2008, 03:51 PM   #18 (permalink)
81240D's Avatar
Date registered: Jan 2007
Vehicle: 1981 240D, 2006 S 430 4 Matic, 2007 GL 450 4 Matic
Fuel
Try Red Line web site is Red Line Oil
also this web site Red Line Oil: Fuel Additives
We used it for 27 years . it works
81240D is offline   Reply With Quote
Old 02-13-2008, 08:30 PM   #19 (permalink)
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -84 230TE (M110 powered)
Where does it leak? i've run a merc diesel on kerosene with no problem..
mbkomfort is offline   Reply With Quote
Old 02-14-2008, 03:19 AM   #20 (permalink)
Zedd's Avatar
Vegetable Oil Fuel is Illegal
FS 2005 SLK & newer: All Weather Floor Mats, Cargo Tray & Wind Screen - $87! dacrow For Sale, Trade & Wanted Items 0 10-21-2007 06:39 PM
$87 OEM Cargo Area Tray & All Weather Floor Mats - for 2005 & newer SLK dacrow R171 SLK Class 1 10-21-2007 11:20 AM
Atlanta biodiesel/SVO get-together djugurba Off-Topic 0 11-15-2004 11:29 AM
Cold Weather & Draining Battery - What To Do? d2e W123 E,CE,D,CD,TD,TE Class 27 12-17-2003 12:49 AM
First flash of sub-'0 weather here - and first "cold weather" accidents Max R170 SLK Class 1 12-11-2002 06:31 AM
