Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 08-19-2007, 09:53 AM   #1 (permalink)
Date registered: Jan 2006
Help!! Won't shut off
1981 240d Car was fine turned off the ignition, still running. Tried the stop lever on the motor, no luck.
any other ideas.?
1967230 is offline   Reply With Quote
Old 08-19-2007, 10:22 AM   #2 (permalink)
Vehicle: 81 300D US & 81 300D EURO & 83 300CD
Check for a second stop lever on the IP pump. USA car?
cytle374 is offline   Reply With Quote
Old 08-19-2007, 11:11 AM   #3 (permalink)
wv240d's Avatar
Date registered: Jul 2004
Vehicle: 1983 240d - 1985 300d - 1984 280sel
You could always just block the air intake- by the way, the stop lever on my 240d is sometimes really hard to press- I've hurt my thumb a couple times getting it to turn off that way. Just be careful you don't burn yourself, those levers can get pretty hot!
wv240d is online now   Reply With Quote
Old 08-19-2007, 11:18 AM   #4 (permalink)
84 bioburner's Avatar
Date registered: Nov 2006
Vehicle: 1984 300D turbo
There is a vacuum diaphram that may be no good??? Or a leak to it, near the IP.
84 bioburner is offline   Reply With Quote
Old 08-19-2007, 11:23 AM   #5 (permalink)
winmutt's Avatar
Date registered: Sep 2005
Vehicle: 85 300D manual+euro+tow+h4
Send a message via AIM to winmutt Send a message via MSN to winmutt
any other ideas.?
Is it over revving? Does the engine rev?
1985 300D Dark Anthracite Grey, 4spd Manual, Euro Bumpers+OEM Tow, Euro Hella 4, 235/15/60 Falken Ziex 15" ACT. Moogs. Bilstein HDs. Vogtland Sport Springs 50mm drop, Muffler Delete Option. 15mm/TD sway bars, SEC brakes. To be Installed: GT2256V. Considering ABS (Do I really want to pull the spindles again?).
1984 TD Smurfette.
OBK #42 4life.
winmutt is offline   Reply With Quote
Old 08-19-2007, 01:15 PM   #6 (permalink)
Fixed.
I had a vacuum leak and the injector pump had been rigged so that the stop lever didn't work.
Stressful not being able to shut off your car though.
Old 08-19-2007, 03:37 PM   #7 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
how long did you have to leave it runing?
'79 280CE with 212,600 miles and still going strong!!
79Mercy is online now   Reply With Quote
Old 08-19-2007, 04:39 PM   #8 (permalink)
4 1/2 hours
Old 08-19-2007, 04:57 PM   #9 (permalink)
Good thing it's a diesel
Old 08-19-2007, 05:04 PM   #10 (permalink)
84300DTurbo's Avatar
Date registered: Sep 2004
Vehicle: 1984 300D Turbo
4 1/2 hours
4.5 hours is nothing. i once drove the car from fla to CT 1400 miles and only shut down once.. ( wanted to get something to eat.. lol )
1984 300D Turbo - 231k.. son's car now... totalled 11/30/07 RIP
send lawyers, guns, & money...
84300DTurbo is offline   Reply With Quote
Shut Up! acarter53 Off-Topic 12 04-26-2007 01:58 PM
Noise upon shut down paulcars GL Class 2 03-22-2007 01:26 PM
Shut Him Up nutz4benz Off-Topic 1 01-25-2007 11:35 PM
Won't shut down 84 bioburner W123 E,CE,D,CD,TD,TE Class 1 11-13-2006 10:57 AM
HeLp PleAsE!? 240d won't shut off, even when I press on shut off switch under hood? turbosing777 W123 E,CE,D,CD,TD,TE Class 18 02-19-2005 03:14 PM
