» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 08-07-2007, 12:05 PM   #1 (permalink)
Tye
Date registered: Dec 2003
power steering pump, rebuild kit or used pump
Hi, was wondering if anyone knows of a online site that sells a rebuild kit for a power steering pump on a 1983 240 D. If no kit is available, I may buy a good used one if anyone is parting a car out. Thanks.
Tye is offline   Reply With Quote
Old 08-07-2007, 03:15 PM   #2 (permalink)
Dieselbenz.info's Avatar
Date registered: Oct 2005
Vehicle: 1982 300D-Turbo
Kits are cheap. $15-$20
http://img.eautopartscatalog.com/live/M204011799.JPG
Take it out and have the shop rebuild it for about $95. There is a metal washer that's a killer to take out and put it back in yourself. I gave up and had the shop do it.
Darrell
http://www.dieselbenz.info/wiki
The ONLY Mercedes Diesel WIKI on earth! 150+ guides, grows and improves every single day!
Dieselbenz.info is offline   Reply With Quote
Old 08-08-2007, 09:05 PM   #3 (permalink)
KCM
Date registered: Jun 2004
What's wrong with yours? I've always thought those pumps were built to outlast the car.
KCM is offline   Reply With Quote
Old 08-08-2007, 09:26 PM   #4 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
wrong, mine started leaking about 2 years ago.
'79 280CE with 210,000 miles and still going strong!!
79Mercy is offline   Reply With Quote
Old 08-09-2007, 10:30 AM   #5 (permalink)
KCM
FYI, there's also a front seal on the shaft behind the pulley. That is the one that is likely leaking.
Old 08-10-2007, 08:27 PM   #6 (permalink)
Date registered: Feb 2007
Vehicle: 1983 300SD, 1984 500SEL, 1985 300DT, 2006 Silverado Z71 crew cab, 1999 Mazda 626 ES V6
In my opinion, buying a rebuilt power steering pump from a reputable supplier is the way to go. Rebuilding your own is tedious and it may still leak or you may not assemble it properly.
Some things, like power steering pumps, and steering boxes are not worth rebuilding by yourself, IMHO.
p100 is offline   Reply With Quote
Central locking pump/PSE pump rebuild. NZ Benz W124 E,CE,D,TD Class 3 07-08-2007 10:22 PM
Vacuum pump rebuild kit or whole new pump 81bobby300D W123 E,CE,D,CD,TD,TE Class 1 03-31-2007 10:51 AM
92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
power steering pump rebuild kit ggenovez Vintage Mercedes-Benz 3 10-11-2006 07:57 PM
rebuild kit for the SLS pump?? Skeeter W123 E,CE,D,CD,TD,TE Class 1 02-13-2006 09:47 PM
