» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 06-25-2007, 10:25 PM   #1 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
A/C troubles
I have posted about this before along time ago. When I speed up fast the a/c goes off. Fan and everything stops(don't know if compressor stops or not). Heres what I've found:
about 50 seconds after the car is off the climate control statrs to loose vacuum. I removed the glove box and watches the diaphram behind it slowly close. I have checked floor diaphram and it is not leaking, I checked the center diaphram and it is capped due to leaking.
After the car is off I can turn the key to the run position directly after car off and the blower will start. About 50 sec. later it goes off and the servo clicks and so do the switches.
The tank in the fender holds vacuum.
Where is the main air flap to all the vents? Does anyone else have any other suggestions where to look. Do you think my servo is failing?
'79 280CE with 215,700 miles
'76 300D with 181,400 miles
79Mercy is online now   Reply With Quote
Headlight Troubles bullyben W201 190 Class 8 09-21-2006 02:48 PM
OIL troubles...what should I do ? mbeclass W124 E,CE,D,TD Class 5 07-23-2006 09:08 PM
Idling Troubles....Please Help RPeters W126 S,SE,SEC,SEL,SD,SDL Class 1 08-15-2004 07:13 PM
82 300D troubles cdv478 W123 E,CE,D,CD,TD,TE Class 8 05-01-2004 07:30 AM
MORE TROUBLES ALEX G-Class 4 02-15-2002 08:17 AM
