Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 06-24-2007, 05:53 PM   #1 (permalink)
Date registered: Dec 2006
85 300D with a vibration around 35 mph
Hello ,
A friend has just purchased an 85 300D with 137,000 mile's on it and he has complained about a vibration at about 35 mph...I know this is little to go on and I'll probably get more information from him the more he drive's it but does any 300D owner's have any ideas he can follow up...?
Thanks, 300se5spd
67300se5spd is offline   Reply With Quote
Old 06-24-2007, 06:44 PM   #2 (permalink)
Date registered: Feb 2007
just at 35 or 35 and above?
could be a bent rim/rims, tire/wheel balance, or a tire issue.
benztech123 is offline   Reply With Quote
Old 06-25-2007, 10:03 AM   #3 (permalink)
I think at 35 - 40 mph....Good try but he has ruled that out ....He's thinking it is a deformed flex disc...I think he'll have it looked at today.....I'll report back but if any other guesses are out there let me know and I'll pass them on to him....
Old 06-25-2007, 12:02 PM   #4 (permalink)
winmutt's Avatar
Date registered: Sep 2005
Vehicle: 85 300D manual+euro+tow+h4
Send a message via AIM to winmutt Send a message via MSN to winmutt
Worn center channel bearing?
1985 300D Dark Anthracite Grey, 4spd Manual, Euro Bumpers+OEM Tow, Euro Hella 4, 235/15/60 Falken Ziex 15" ACT. Moogs. Bilstein HDs. Vogtland Sport Springs 50mm drop, Muffler Delete Option. 15mm/TD sway bars, SEC brakes. To be Installed: GT2256V. Considering ABS (Do I really want to pull the spindles again?).
1984 TD Smurfette.
OBK #42 4life.
winmutt is offline   Reply With Quote
Old 06-25-2007, 05:03 PM   #5 (permalink)
Winmutt ,
Good idea.. but I think a faulty bearing would make noise rather than vibrate. Also, a noise would intensify with speed…
Old 06-25-2007, 06:43 PM   #6 (permalink)
winmutt's Avatar
No its the rubber that keeps the drive shaft in place around the bearing. If the flex discs are warped, how do you think this happened.
Old 06-25-2007, 07:42 PM   #7 (permalink)
Winmutt,
I'm quoting the owner who isn't signed on here yet ....He had the car up today and he say's :
"The flex discs are relatively new and they must’ve been replaced at one point. The hanger bearing assembly is all intact. No visual wear or damage."
Any other ideas....?
Old 06-25-2007, 08:12 PM   #8 (permalink)
BenzWorld Elite Host
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
What size tires is he running? Oversized tires can result in a harsher ride.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline   Reply With Quote
Old 06-26-2007, 08:05 AM   #9 (permalink)
winmutt's Avatar
What kind of vibration? Where is he feeling it? Where does it seem to be coming from? (I feel it in the steering wheel and hear it from the front left)? Did the mechanic check to see if the the drive shaft was properly aligned? They may have seperated them to the the flex discs.
Old 06-26-2007, 08:58 AM   #10 (permalink)
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 1983 300DT, 2000 Z3, 2007 R320 CDI
drive shaft needs to be re-balanced perhaps?
drive shaft vibration feels different than wheels out of balance. It's more of a slight shudder through the whole car...
chucelli is offline   Reply With Quote
Vibration at 75 mph ???? Racergenx R129 SL Class 34 09-07-2007 01:19 PM
Vibration at 60-80 MPH lynns R129 SL Class 25 11-17-2006 03:44 PM
vibration at 60 mph nkpnkp W124 E,CE,D,TD Class 6 04-23-2006 05:44 AM
60 - 70 mph vibration Malfetti R129 SL Class 7 06-01-2004 06:50 PM
Vibration at 75 MPH. grok W163 M-Class 6 04-21-2004 06:01 AM
