» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-27-2007, 06:52 PM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 300SD
Angry diesel engine thermostats
I have tried 2 brand new brand name 80 degree C rated thermostats in my '83 300DT. The car consistently runs at 95 degrees C. Even after I put in a new temperature sending unit. The original thermostat that the car came with when I bought it a few months back, makes the car run at 80-85 degrees. I replaced it only because it evidently was sticking open a bit as it took a long time for the car to warm up. Now I put it back in the car. It runs steady at 80 degrees and never goes beyond 85. The only penalty is that the car takes much longer to warm up.
I replaced the thermostat in my 300SD about three years ago. The car steadily runs at 85 degrees C and warms up pretty quick.
What I have concluded is that at some point all these new 80 degree rated thermostats have been calibrated to actually open at about 90 degrees C. For what reason I have no idea - maybe hotter running diesel has less harmful emissions? At any rate, I really believe that there is nothing wrong with my car or its cooling system, except I cannot find a new 80 degree thermostat! because they evidently do not make them anymore, despite stamping 80 degrees on them.
I hear similar complaints from other people. In fact, there is a long article on the same subject on dieselgiant.com Has anybody put one of these new thermostats in water to see at what temperature it opens? If anybody knows of any new thermostat that actually opens at 80 degrees that fits these cars, let me know. I am getting really tired of this. Now I have a brand new radiator sitting in a box, which will evidently do nothing, because it will run again at 95 degrees with one of these stupid new thermostats!
p100 is offline   Reply With Quote
Old 05-27-2007, 07:05 PM   #2 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
I guess this is a 80C t-stat: Your Parts Search Returned 1 Part(s)
'79 280CE with 215,700 miles
'76 300D with 181,400 miles
79Mercy is offline   Reply With Quote
Old 05-27-2007, 07:08 PM   #3 (permalink)
Date registered: Mar 2007
Vehicle: 1990 500SE
I have read somewhere here on these forums that the 80 C t-stats are made to open up at 87 C so you are close with your 90 C est.
108Benz is offline   Reply With Quote
Old 05-27-2007, 07:22 PM   #4 (permalink)
Vehicle: 300SD
Thanks, but I already tried theirs and it is NOT an 80 degree thermostat!
Old 05-27-2007, 07:29 PM   #5 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
What about this one: Sunvalley New Mercedes Parts
Old 05-27-2007, 07:48 PM   #6 (permalink)
Vehicle: 300SD
Thanks. I may have to buy something else too because shipping is $ 10.70, almost as much as the T stat itself!
Old 05-27-2007, 08:16 PM   #7 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
I bought one from these people a while back and it is a 80C t-stat.
Old 05-27-2007, 08:20 PM   #8 (permalink)
Vehicle: 300SD
That's just it. A while back (about 3 years ago) I bought one for my other car and it too was an 80 degree one. So they must have modified these recently to open at higher temperature. Is this annoying, or what! I never realized that a thermostat could be such a pain in the neck!
Old 05-27-2007, 08:24 PM   #9 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
where did you buy the one for your other car?
Old 05-27-2007, 08:32 PM   #10 (permalink)
Vehicle: 300SD
I got it from thebenzbin.com. I do not remember what brand it was , I believe it was either a Behr or a Wahler.
Diesel engine noise bender W123 E,CE,D,CD,TD,TE Class 7 01-21-2007 09:44 PM
Diesel engine oil for gas Mercedes engine?? why? ProV1x General Mercedes-Benz 2 11-06-2006 11:27 AM
6 cyl.diesel to 5 cyl. diesel engine swap getgsd W126 S,SE,SEC,SEL,SD,SDL Class 4 09-08-2006 04:15 PM
What engine oil ( diesel )? Uber Huge W123 E,CE,D,CD,TD,TE Class 4 06-05-2006 05:30 AM
diesel engine? jshaddvw Vintage Mercedes-Benz 1 04-25-2004 06:59 AM
