Repair sunroof? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-20-2007, 02:30 AM Thread Starter
Repair sunroof?
Hi,
I have a 1980 300D.
My sunroof is a really slow when sliding back and forth, and I am wondering how difficult it is to repair this problem? Do I need to tear out the headliner and replace a motor? Or is it just an issue of adding a little WD-40?
elbalazo is offline
post #2 of 4 (permalink) Old 05-20-2007, 03:45 AM
Date registered: May 2005
Vehicle: 2008 CLK550, 2012 C300
Quoted: 2 Post(s)
You need to clean and re-grease the sunroof tracks with M/B sunroof grease.
Remove the drive cable, clean and re-grease.
Clean the cable tube back to the drive motor.
Assemble and enjoy. About 1.5 hours.
Lots of threads
Thanks,
Zill.
Zill is offline
post #3 of 4 (permalink) Old 05-20-2007, 06:09 AM
Gregs300CD's Avatar
Vehicle: 1982 300CD
Quoted: 10 Post(s)
Check out Mercedessource.com. They have a kit with instructions.
Gregs300CD is offline
post #4 of 4 (permalink) Old 05-20-2007, 06:48 AM
Date registered: Feb 2007
Vehicle: 300SD
Quoted: 62 Post(s)
I have to endorse that advice. I bought one of these kits myself or about $ 40. The instruction booklet that comes with the kit is the most important. Without it, you can easily mess things up and end up with an expensive repair.
p100 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    sunroof repair Roadhouse_wannabe W126 S,SE,SEC,SEL,SD,SDL Class 21 09-11-2012 05:14 PM
    91 300 se sunroof parts & repair Rob Weamer W126 S,SE,SEC,SEL,SD,SDL Class 3 05-14-2010 01:26 AM
    Repair or replace a 1998 A160 sunroof?? jvallet W168 A-Class 0 05-10-2005 03:14 AM
    Sunroof repair Help? Sandro N W210 E-Class 2 02-16-2005 06:19 PM
    Sunroof Repair Kit srep W126 S,SE,SEC,SEL,SD,SDL Class 5 12-12-2002 09:21 PM
