» Site Navigation » Other Sites
03-12-2007, 11:14 PM
#1 (permalink )
Date registered: Oct 2006
Vehicle: 1982 300d turbo-diesel
83 240d tranny swap!!
Hi all , I was thinking of swapping my auto tranny to a 4-speed manual... I know i will need the diveshaft,slave cylinder,pedal,... Is it worth it and what will i need to do it right?
Thanks
Bruce
03-13-2007, 12:03 AM
#2 (permalink )
Date registered: Feb 2004
Vehicle: 80 240D 3.0VNTi
If you are keeping the stock 4-banger engine, it's a simple swap-n-bolt-in process.
It will be much more easy if you have a parts car near by to swap from.
1980 240D 3.0VNT 222k miles
Modifications (Link) : OM617.952, 4-speed manual, GT2256V VNT turbo, W115 300D intake, ALDA/EGR/rack limiter removed, 3.46 diff, 15mm rear sway bar, Amsoil bypass oil filter, Mobil1 5W-40 synthetic oil.
"You call parking a supersonic jet in front of a titty-bar 'inconspicuous'?"
youtube.com/Turbo617 http://superturbodiesel.com
03-13-2007, 07:05 AM
#3 (permalink )
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Did mine about eight years ago - best thing I ever did to that car. I've got a short write up of the job in my files. If you want it, contact me off list at
len@sokoloff.com .
Len
03-13-2007, 01:27 PM
#4 (permalink )
Date registered: Oct 2005
Vehicle: 77' 6.9, 74 240D, 76 300D, 1996 Ram 5.9L Cummins
Bruce, if you're interested I have a 4 speed tranny and the shift rods sitting in a box in my living room. Where are you in CA?
1977 - W116 - 6.9
1976 - W115 - 300D - Disassembled
1974 - W115 - 240D 4 SP Manual - Almost under Turbo OM617 Power!
03-13-2007, 01:39 PM
#5 (permalink )
I'm in san diego and still thinking if i should swap.... Because i got a really good tranny, so i'll let you know if i decide to swap it out ....
Thanks
Bruce
03-16-2007, 05:13 AM
#6 (permalink )
Date registered: Mar 2007
Vehicle: 88 300E 5 Speed Manual
Having driven well over 800,000 miles in manual transmission 240D's, I would highly recommend this mod. You will find fun in driving your little four that you never knew about.
My $0.02,
Larry Bible
Change oil HOT and change oil OFTEN.
'88 300E, 5 speed manual
ASE Master
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post tranny swap a1jatt W201 190E, D-Class 1 07-27-2006 08:35 PM 1976 240d Bumper Swap? droorz77 Vintage Mercedes-Benz 1 04-12-2006 07:46 AM tranny swap freshyip W210 E-Class 2 11-16-2004 01:42 PM '83 240D A/T swap to 4-spd manual RoyH W123 E,CE,D,CD,TD,TE Class 8 08-10-2004 05:18 PM can i use a 300td engine in my 240d, as a swap? merk em W123 E,CE,D,CD,TD,TE Class 1 12-16-2002 09:07 PM
