Rear Bumper Impact Strip Install: Any Tips? - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 02-12-2007, 02:22 PM Thread Starter
booradley5's Avatar
Date registered: Jan 2007
Vehicle: 1984 300TD
Send a message via AIM to booradley5
In the continuing saga of cosmetic rehab on my 84 300TD, I'm having trouble getting the rear bumper impact strip installed. I thought this would be easy, but noooo...
It's essentially two mounting brackets that snap onto the bumper with a grooved rubber strip on the back of the impact strip itself.
What's so frustrating is that the rubber strip takes an amazing amount of force to slide on or, when I tried to just snap it over the grooves, it's just not pliable enough. Oh and then getting it aligned...
I don't want to break the brackets forcing this on, so any tips appreciated.
Thanks!
booradley5 is offline
post #2 of 28 (permalink) Old 02-12-2007, 06:59 PM
Date registered: May 2005
Vehicle: 2008 CLK550, 2012 C300
Quoted: 2 Post(s)
Lubricate with glycerol or dilute soap
Zill is offline
post #3 of 28 (permalink) Old 02-12-2007, 08:06 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
Spray hairspray on the backside of the rubber as you push it on but work fast.
Surely everyone remembers this trick from when they owned bicycles and putting on the handgrips
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #4 of 28 (permalink) Old 02-12-2007, 08:12 PM
Date registered: Jul 2004
Send a message via MSN to panamacolin
yeah grease it up wd-40 then the tabs on the backside slide from left to right to lock the rubber bumper in place. I used a flat piece of wood and a rubber mallet to knock the the rubber knubs on the inside of the bumper into the locked position...
panamacolin is offline
post #5 of 28 (permalink) Old 02-12-2007, 08:28 PM
Boring Cars...meh!
Quoted: 17 Post(s)
WD40 will ruin the rubber
post #6 of 28 (permalink) Old 02-12-2007, 08:33 PM
ok dont use wd-40...good to know...I dont know what i used last time but I could have used wd-40...
post #7 of 28 (permalink) Old 02-12-2007, 08:34 PM
and from what i can remember i think the tabs on the inside of the bumper are plastic and not rubber...not 100% sure
post #8 of 28 (permalink) Old 02-12-2007, 08:39 PM
Boring Cars...meh!
Quoted: 17 Post(s)
Yeah,it breaks down the rubber seeing that it's oil.
Little reading for you to skim through,pick whichever on the search results.
wd40 on rubber - Google Search
post #9 of 28 (permalink) Old 02-12-2007, 09:06 PM Thread Starter
booradley5's Avatar
Vehicle: 1984 300TD
Wink
Thanks. I'm going to try the glycerine/soap method since getting everything lined up is a bit of a challenge and I'll need to work it around a bit. Believe it or not, my girlfriend does not have hairspray in the apartment, but she does have, some, uhh..."Glycerin-based" product that will come in mighty handy. Will let ya know how it goes tomorrow!
btw--the mounting bracket is 100% very fragile plastic
post #10 of 28 (permalink) Old 02-12-2007, 10:06 PM
Premium Member
ducatipaso's Avatar
Date registered: Jul 2006
Premium Member
Send a message via AIM to ducatipaso
Interesting mix of claims about WD40 and rubber.
Personally, I've never had a problem with it.
ducatipaso is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
    euro impact strip (bumper) quddous W203 C-Class 8 10-06-2006 10:02 PM
    front bumper impact strip rob_fed W210 E-Class 0 08-07-2006 06:20 PM
    Rubber on rear bumper "impact strip" came off... How to reattach??? jtoma878 W123 E,CE,D,CD,TD,TE Class 4 01-31-2005 02:47 PM
    bumper impact strip for sale? esputmono W203 C-Class 3 09-17-2003 12:34 AM
    how to remove rear bumper impact strip? Guest (MBNZ) W203 C-Class 2 04-03-2002 07:24 PM
