Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 01-22-2007, 10:13 PM   #1 (permalink)
Date registered: Dec 2006
72 220d manual tranny in a 76 240d possible?
I have a 72 220d with a manual transmission. Would it be okay to put it in my 240D which has a s...l....o....w... auto tranny? would it make it slower or would it work fine or mess up?
1976240D is offline   Reply With Quote
Old 01-23-2007, 01:46 AM   #2 (permalink)
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: 77' 6.9, 74 240D, 76 300D, 1996 Ram 5.9L Cummins
It should bolt up, I haven't done it but the motors are nearly identical and it would give it some more control of the rev range.....all 4000rpm's or so
1977 - W116 - 6.9
1976 - W115 - 300D - Disassembled
1974 - W115 - 240D 4 SP Manual - Almost under Turbo OM617 Power!
diametricalbenz is offline   Reply With Quote
Old 01-23-2007, 02:52 PM   #3 (permalink)
Is that bad? only 4000 rpms? i thought they can do like 5000 rpm
Old 01-23-2007, 03:16 PM   #4 (permalink)
Well anyways, can you guys give me some instructions to swap out an auto for a manual, and everything ill need from the manual car to put in mine?
Old 01-24-2007, 09:07 PM   #5 (permalink)
Date registered: Aug 2004
Vehicle: 1983 240D auto..soon to run a generator in the country.1984 300D turbo 4 spd
Absolutely the best post I've seen re: a switchover to a manual tranny.
Auto -> Manual Transmission Conversion Has Begun. - ShopForum
There are so few things I can actually count on like the feeling of security and safety I feel in this smelly ol' car.
Maybe I'm hard of hearing but it sounds like purring....
RoyH is offline   Reply With Quote
81 240d manual tranny center support failure question Cobb2 W123 E,CE,D,CD,TD,TE Class 0 11-26-2006 12:02 PM
What is the 240d manual tranny cruse control like Cobb2 W123 E,CE,D,CD,TD,TE Class 1 10-25-2006 07:58 PM
81 240d manual tranny noises Cobb2 W123 E,CE,D,CD,TD,TE Class 10 09-23-2006 03:41 PM
Shifting points for 81 240d manual tranny Cobb2 W123 E,CE,D,CD,TD,TE Class 12 08-10-2006 08:39 PM
early 70's 220D and 240D fuel delivery catfish Vintage Mercedes-Benz 0 12-25-2005 10:11 PM
