» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 01-12-2007, 10:42 PM   #1 (permalink)
Date registered: Oct 2005
Vehicle: 1983 300TD wagon
What is the hottest thermostat available?
I'm running my 1983 300TD on WVO. Today never got above zero degrees Farenheit. The car sat outside all day and started right up, but it took me 10 miles to switch over and the inside of the car hardly got warm. I have most of the radiator covered. I have searched for a hotter thermostat than the factory 80 degree C, have not been able to find one. Does anyone know if another thermostat will fit and get me a higher temp? Thanks!
Arne.
1983 300TD wagon. Bought at 255,000 miles, dark blue with tan interior. Converted to WVO at 258,000 miles, now over 324,000 miles and running great. Car is in nice condition overall with the usual vacuum problems (being sorted out slowly).
avainio is offline   Reply With Quote
Old 01-12-2007, 11:34 PM   #2 (permalink)
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
How hot does the temp gauge get?
youtube.com/Turbo617
Zedd is offline   Reply With Quote
Old 01-13-2007, 07:56 AM   #3 (permalink)
bary123ce's Avatar
Date registered: Jan 2007
Vehicle: 560 SEC, W124 300DT 4-Matic, C123 230CE, W124 300TDT '95, C123 300CD Turbodiesel
Send a message via Yahoo to bary123ce Send a message via Skype™ to bary123ce
I think the thermostat should open with 82 degrees. There are also 85 degrees available, of course I mean in Europe. Don't know if in US also...
bary123ce is offline   Reply With Quote
Old 01-13-2007, 10:38 PM   #4 (permalink)
The temp gauge runs a little above 80 when the car is warmed up. The cardboard does help, but it would be nice to get up to temp sooner. I don't like to switch until the engine is at operating temp. Even though it's been a warm winter I end up using more dino than I want to.
Old 01-13-2007, 10:51 PM   #5 (permalink)
Zedd's Avatar
That's right where it should be. A higher t-stat won't get it warm any quicker, it will just run hotter.
Old 01-14-2007, 07:52 AM   #6 (permalink)
Date registered: Dec 2006
Vehicle: 1984 300D turbo 311,965 miles, anthracite metallic/palomino series No. 4141. [T-A-N-K]
although a bit hotter=better with WVO and that iron horse motor will retain the extra heat. minor difference, however.
phideauxiii is offline   Reply With Quote
Old 01-15-2007, 01:19 PM   #7 (permalink)
Date registered: Jun 2006
Vehicle: 1981 300CD
How old is this thermostat? I think its not closing fully. You should get to 80 c in about 2 miles, not 10. Simple to remove and verify its completely closed cold.
carnut1 is offline   Reply With Quote
Old 01-15-2007, 08:26 PM   #8 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
My 280ce runs almost to the 100c. line. It would run just a touch above 80c. a long time ago before I started to have trouble with it running hot. Is it okay to run just just alittle under 100c. In hot weather in traffic it will go just alittle above 100c. Is this normal or is there something still wrong with the cooling system?
'79 280CE with 215,700 miles
'76 300D with 181,400 miles
79Mercy is offline   Reply With Quote
Old 01-16-2007, 11:32 AM   #9 (permalink)
Vehicle: 1981 300CD
100 C is within spec, its not running "hot" its running a little warm. Wouldn't hurt to replace the radiator cap. Could be weak lowering the boiling point. Being a gas car , I would verify timing at spec, could be slightly retarded which might raise engine temp.
Old 01-16-2007, 02:12 PM   #10 (permalink)
rrgrassi's Avatar
Vehicle: '82 300D
The T-Stat I bought at NAPA is the 90 degree C one. I am planning on getting the 80 degree fail safe one, though. The PO, or his ham fisted mechanic left the T-Stat out of my car. I did not notice this until cooler weather hit, and the car would not warm up past 60 degrees C.
RRGrassi
82 300D 268,000 Warndreicke in the trunk. odo repaired--again
06 Jetta TDI 80,000
rrgrassi is offline   Reply With Quote
Hottest 19" wheels? Mr. Corporate W203 C-Class 6 10-26-2005 10:17 PM
Thermostat wv240d W123 E,CE,D,CD,TD,TE Class 2 01-30-2005 05:45 PM
The Hottest 40+ women FeelTheLove Off-Topic 30 01-28-2005 10:47 PM
Hottest car! BOY-6 W163 M-Class 28 02-06-2003 02:30 PM
Thinking of buying this CLK.....hottest clk!!! a must look!!!!!!!!!!!!!!! Stefan W208 CLK Class 7 11-18-2002 12:59 PM
