» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 12-07-2006, 02:58 AM   #1 (permalink)
hotwheelbill's Avatar
Date registered: Jul 2006
Alada....what can a turn hurt?
I am ready to get a little more out of my 85' 300D and want to turn up the boost. How can pulling off the alada cap hurt the pump? Can I pull the alada and put in a spacer instead of turning the screw?
hotwheelbill is offline   Reply With Quote
Old 12-07-2006, 06:02 AM   #2 (permalink)
79-300SD's Avatar
Date registered: Jan 2005
Vehicle: 1979 300SD, 1983 300D Mercedes
Send a message via AIM to 79-300SD
only hurt the pump if you turn it too far and break the alda. adjust it too much one way you lose economy...adjust it too far the other way you lose power.
Speed is a question of money. How fast do you want to go?
Proud Owner of a
1979 W116 300SD
1983 W123 300D
Come join us at http://schumanautomotive.com/forums
79-300SD is offline   Reply With Quote
Old 12-07-2006, 06:17 AM   #3 (permalink)
Date registered: Dec 2006
What in the name of God is the "alda" ?!
Eduardo CC is offline   Reply With Quote
Old 12-07-2006, 07:18 AM   #4 (permalink)
79-300SD's Avatar
Look at the square thing on top of the rear of the Injector pump. It will have a hose running over to an over boost solenoid than the rear of the intake. It senses boost pressure and allows an adjustment to set a baseline under non-boost conditions. with wear your off boost fuel delivery will be less than optimum..therefor a slow spool then power when the boost comes in power wise.
THe Non-turbo engines don't have an ALDA but the do have an altitude compensator which works in a similar manner based on atmospheric pressure.
ALDA is an acronym for a longer german phrase.
Old 12-07-2006, 08:07 AM   #5 (permalink)
Thanks!
I think I got it now...
Old 12-07-2006, 10:18 AM   #6 (permalink)
Date registered: Oct 2006
Vehicle: 1980 300 TD
Originally Posted by Eduardo CC
Thanks!
But I still don't....
Did a quick search on this site, and Google, and passed by a lot of sites. So now I know where it sits on the engine (or beter fuel system), and merely know it's function, but still don't know what it means..
The fact that it is a shortend german phrase made me dig out my brains even more cause my german is actualy quite good.. and so is my thechnical knowledge, which gives the situation that I woulden't be amazed if I even know the name in German (or Dutch).
But i just can't figure it out..
So please help me out!!
PS (Not that it's of any use, cause I own a non-turbo 300TD. But I just have a strong need to know.. Out of interest.. Learning every day.. )
Haplo is offline   Reply With Quote
Old 12-07-2006, 10:33 PM   #7 (permalink)
~BANNED~
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 82 300D VNT, 80 240D 3.0T
Automatische LadeDruck Anreicherung
Literal translation: Automatic Load Printing Enrichment
There are some people (myself included) that completely REMOVE the ALDA. This gives a more instant (crisp) response to pedal input and minimizes the "rush" as the turbo kicks in.
Zedd is offline   Reply With Quote
Old 12-08-2006, 01:53 AM   #8 (permalink)
Thanks so much!
The literal Translation is a but dirty though.
Lade, is the word for the Turbo itself. Druck is correctly translated as Pressure.
So litterly its the word for the pressure wich the Turbo generates.
Correctly translated I would make it something as: Automatic Charging-pressure Enrichment.
But both German and English are not my first languages... So correct me it does not make any sense at all..
Stangly enough I could find more and interesting articles about the ALDA in English than in German (when using the actual right german translation). So that only proves i'm using the right forum (The Dutch Forum is useless anyway), for wanting to know more about the technical side of our car..
Old 12-08-2006, 03:49 AM   #9 (permalink)
O.K., now I am in somewhere I know nothing about.......but I want more!
What would it take to remove the alda and what is it going to hurt or I should say, disrupt, on the motor. How would than run with burning WVO.
http://i63.photobucket.com/albums/h1...rsystem009.jpg
Old 12-08-2006, 07:22 AM   #10 (permalink)
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
If you want a picture of the ALDA unit, it is picture 2, letter T...
http://www.benzworld.org/forums/w123...nce-pages.html
Gregs300CD is offline   Reply With Quote
The pictures hurt..... edstorm W140 S-Class 19 07-08-2006 09:56 AM
It really starts to hurt now NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 37 08-18-2005 06:28 AM
This is going to hurt, but .......... Birger W163 M-Class 18 01-14-2005 09:52 AM
This is going to hurt, but..... Birger W164 M-Class 7 01-12-2005 09:19 PM
OT: Thats gotta hurt S4toML W163 M-Class 21 02-21-2003 08:58 PM
