» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-20-2006, 04:43 PM   #1 (permalink)
Date registered: Oct 2005
Vehicle: 79 300SD
Oil pan removal and I found...
I removed the oil pan to change the leaking gasket today. After removing the pan, the screen and washers/gaskets that attaches to the bottom of the oil pump fell off too. This screen and surrounding plastic pieces are cracked, broken, and in overall bad/unusable shape.
I went to the local stealership and asked about this part. First stealership response: "You need a new oil pump." Second response, “We do not carry, stock, or even know how to get this part." Third response, "We'll try to track one down."
Can anyone offer experience and knowledge here? I've browsed Autohaus with no results, other than the entire oil pump assembly. And, I’d rather stay away from the money hungry stealership.
2005 VW Passat 1.8t 4Motion w/ 5 spd
1979 MB 300SD Turbo Diesel - happily enjoying ownership since 1994
Chaw is offline   Reply With Quote
Old 11-20-2006, 04:54 PM   #2 (permalink)
Das Einwohner Arschloch
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: Mercedes-Benz & BMW
I forgot what diesel model and year you have but this may get you on your way.
http://www.mercedes-benz-parts-direc...epc-search.asp
Nutz 4 Benz is offline   Reply With Quote
Old 11-20-2006, 05:02 PM   #3 (permalink)
Vehicle: 79 300SD
Thanks.
Sorry, it's an 82 300D OM617.
The attached photo is of an oil pump. I need the black plastic pieces that surround the screen within. (on top in the photo, at the bottom of the pump when mounted on the car)
Old 11-20-2006, 05:11 PM   #4 (permalink)
The sleeve?
Old 11-21-2006, 09:26 AM   #5 (permalink)
JamieK's Avatar
Date registered: Mar 2006
God, are some dealerships that frickin' lazy?!!?
This is a turbo engine, correct. You need a part number 110-180-03-55. Less than $20. Includes the rubber extension and screen.
Just the rubber extension is part 110-186-00-07. About $10.50.
Jamie
But then again, I could be wrong.........
Where is everyone? Find out here (and let everyone know where you are, too)...
http://www.frappr.com/w123club
JamieK is offline   Reply With Quote
Are these gaskets light or heavy wear? (Oil pan & oil filter) Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 9 08-24-2006 07:57 AM
oil pan removal help euroamg W126 S,SE,SEC,SEL,SD,SDL Class 2 03-21-2006 06:10 AM
Possible??? : Tube from oil breather to oil pan being totally clogged?? AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 0 08-26-2005 02:32 PM
oil pan??? xscottyx W201 190 Class 3 01-27-2004 06:04 AM
Need help on Oil Pan removal in 300CE Guest (MBNZ) W124 E,CE,D,TD Class 0 05-22-2001 03:58 AM
