Replacing Headlight - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-05-2006, 12:56 PM   #1 (permalink)
RubyRed's Avatar
Vehicle: 1982 240D
Replacing Headlight
Hey everyone,
my left headlight is dead so I bought a new one from AutoZone. It's not a Bosch like my other ones but it's a Sylvania (the guy looked it up in the computer and that's what was suggested). Anyway, I'm absolutely stumped in going about to get the old one out and putting the new one in. The instructions aren't that clear (atleast not to me). Any ideas? Thanks!
"Her mind is definitely twisted, she got a Mercedes-Benz, uh, she got a lotta pretty, pretty boys she calls friends..."
RubyRed is offline   Reply With Quote
Old 11-05-2006, 01:02 PM   #2 (permalink)
smallfence's Avatar
Date registered: Jan 2006
Vehicle: 1981 240D
  1. pop the hood
  2. look on the backside of the headlight assembly (from inside the engine bay)
  3. you'll see three white knobs that hold on the gray plastic "headlight surround" which are on the outside of the car (they surround the headlight and foglight)
  4. loosen all three white knobs
  5. the gray headlight surround should then slide out if you pull it away from the car.
  6. now, you have exposed the headlight and foglight
  7. there are three little phillips screws holding on a ring which holds the headlight in place
  8. unscrew those screws, then pop the ring off (pull it towards you/away from the headlight and car
  9. the actual headlight will now be loose, just unhook the harness from the back
  10. plug in the new headlight and reverse all the procedures
I apologize if I missed anything but I'm writing this from memory. At the very least I am sure that this is the basic outline. It's a very easy job and I'm sure you can think your way through it.
20,000mi on biodiesel and counting!
smallfence is offline   Reply With Quote
Old 11-05-2006, 03:27 PM   #3 (permalink)
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Also before doing that, verify the left headlight fuse isn't cracked or corroded !
carnut1 is offline   Reply With Quote
Old 11-05-2006, 08:24 PM   #4 (permalink)
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W123, W201, W124
If you had a Bosch headlight, keep it. Chances are it may be the E-code conversions where the bulb can be replaced and you don't need to get a new sealed beam. Get an H4 bulb (HB3 I think is another alternate name) and you'll be fine.
Youngtimer
MBeige is offline   Reply With Quote
Old 11-05-2006, 08:26 PM   #5 (permalink)
smallfence's Avatar
Vehicle: 1981 240D
could it be possible that a bosch sealed beam came standard as oem?
Old 11-05-2006, 08:34 PM   #6 (permalink)
MBeige's Avatar
I don't think Bosch made a sealed beam unit. Most of the old w123s I see have either Sylvania or Wagner lights on them.
Old 11-05-2006, 08:52 PM   #7 (permalink)
smallfence's Avatar
Vehicle: 1981 240D
hmm, well that'd be a pretty sweet find if she already had the e-code lights!
rubyred, if you you unhook the harness from the back of the light and a little bulb slips out of the bigger lamp housing, follow karugs' advice and return that sealed beam and get a replacement H4 bulb. if the light is just one piece, go ahead and replace the whole unit.
you can see a hole the back of the lamp unit in this photo
http://www.rallylights.com/hella/hel...ages/7%20E.jpg
the lights in the photo are the kind with the replaceable H4 bulbs. if they don't have a hole back there, but rather just a 3-prong connector built into the lamp, you have to replace the whole thing. hope this makes sense
Old 11-06-2006, 11:19 AM   #8 (permalink)
DieselKraut22's Avatar
Date registered: Apr 2005
Vehicle: 1985 Euro 300TD Turbo, 1983 Euro 300TD turbo, 1979 Euro 240TD and 1981 300D converted to euro.
Send a message via AIM to DieselKraut22 Send a message via Yahoo to DieselKraut22
both my 84 turbo 300D and my 77 300D had the bosch sealed beams
1977 300D
1980 300D EU
1980 300TD
1980 300TD
1981 300D
1981 300SD
1982 300SD
1982 300D
1982 300D
1982 300CD
1983 240D
1983 300D
1983 380SEL
1983 300D
1983 300D EU
1984 300D EU
1984 300D
1984 300D
1984 230E EU
1984 300D EU
1984 230E EU
1985 300D
1985 300TD
1985 300TD Turbo EU
1982 240D
1982 240D
1980 240D
1979 240TD EU
1979 240D
1979 280CE AMG EU
1983 300TD Turbo EU
1984 300TD Turbo
1978 230C EU
1978 300CD
1978 300CD
DieselKraut22 is offline   Reply With Quote
Old 11-06-2006, 07:57 PM   #9 (permalink)
RubyRed's Avatar
Vehicle: 1982 240D
So...wait this might be a dumb question but could I have just bought a little bulb instead of having to buy a whole new lamp? What's wrong with me?
Old 11-06-2006, 08:13 PM   #10 (permalink)
smallfence's Avatar
Vehicle: 1981 240D
you likely need the whole new lamp. there is nothing wrong with you because that's what the McPart's guy told you, and usually that would be correct. The E-code thing Karugs and I are talking about is a special aftermarket light that some owners choose to put in their cars. I would guess there's a 90-95% chance that you have the right replacement. but, the only way to know for sure is to just take out the old one and see what you have.
Bookmarks
replacing headlight bulbs sagamol W124 E,CE,D,TD Class 6 01-06-2006 05:01 PM
Replacing Headlight bulb for 190E kytrex W201 190 Class 1 07-21-2004 04:13 PM
Any DIY for replacing headlight glass? pds22 W140 S-Class 1 11-04-2003 08:46 AM
Replacing headlight on 97 e420 Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 12-03-2001 06:53 PM
Need help replacing headlight bulb Guest (MBNZ) W203 C-Class 1 02-25-2000 12:48 PM
