Bboy, car looks great! So that's what 2 coils will look like... I'm in.
As already confirmed the wheels are 16" CLK 320 wheels, they are all aluminum and VERY light. I swear they weigh as much or less than 14" bundts, I held one in each hand. They are not staggered, the front center cap will not fit over the grease cap and there is literally 1/4" gap between the inside edge and the tie rod. I've got a set of 12mm spacers but being so damn low that puts the tire way too close the fender lip for my comfort so I'll probably just "modify" the grease cap to allow the center cap to fit. Anybody want to buy 4 12mm hubcentric spacers with longer lug bolts?
And yes the are stock springs I cut, 3 coils off the front and 1.5 off the rear. Idealy it seems 2 front and 1.5 rear would have been the smarter choice, tis the reason I just bought a new set of front springs to try again. The ride is very near to stock but I can tell I'm past the efficient damping range of the shocks. HDs probably would have helped a bit but probably not night and day. Hopefully bringing the front up a bit will get me more in that usable range and smooth out the bound and rebound when going over small bumps. I have noticed DRAMATICALLY less body roll when turning, it doesn't feel like a boat ready to keel over anymore. Stay fairly flat without being jarring. I think the best route would have been Vogtlands with a coil or two cut that way you get the higher spring rate and drop however the ride will be somewhat harsher.
Why is that a bad idea? I'm guessing the ride sucks?
1982 240d.
Sienna Pinpoint MB Tex
188,000 miles (as of March 18, 2008)
185,000 miles (as of February 21, 2007)
183,000 miles (as of October 29, 2007)
I dont know if i ever posted my car totally finished. This is 2 coils in front, SLS dropped in the rear (worst idea ever) with all the euro gear on it.
Looks good, I've gotta do the front on mine, as it's stock fronts and AMG rears. Check your PM's btw
how is the tire wear, were you able to do a good alignment? im thinking that much of a drop would have the camber adjustment maxed out
__________________ 7/81 US 280CE M110.984 metallic anthracite grey, tan mb-tex 80 EURO 280CE M110.984 english red, white cloth interior 62 chrysler newport 4DR white 361 V8, 35,100 miles 66 chrysler 300 2DR blue 383 V8, 74,000 miles
-looking for 190d project local, sale or trade
Well it's only been 3 days so not too sure of the tire wear. I can tell you however that I have just a bit of negative camber with a lot of adjustment left. I'm waiting until I get my new coils before taking it in for an alignment, but I eyeballed it and so far it feels good on the road.
