Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 08-10-2006, 10:24 AM   #1 (permalink)
hotwheelbill's Avatar
Date registered: Jul 2006
85 300d operating temp.
I need to know the correct operating temp. of my 300d diesel 1985. It has a split in the plastic resovier overflow for the radiator and the temp while driving is about 85c and when idol it went up to 110c before I could turn it off. The outside temp. is 96*.
hotwheelbill is offline   Reply With Quote
Old 08-10-2006, 01:28 PM   #2 (permalink)
WeVonBraun's Avatar
Date registered: Sep 2005
Vehicle: 1984D300
Anything under 100C is acceptable I would say. 85C is a fix for some maniacs(uncluding me).
Boiling at the measuring point (somewhere very near the termostat) is NO GOOD. I suggest you fix the cooling system "expansion tank" and keep on using centigrades instead of *'s. Although 96 IS pretty hot, I must agree.
-- wvb
WeVonBraun is offline   Reply With Quote
Old 08-10-2006, 03:15 PM   #3 (permalink)
I changed the tank in the parking lot next to the MB dealer and replaced the cap. No good. I am now changing the thermistat. When I pulled the lower hose from the therm housing, it was not wet!!
Engine operating temp graftdesign W126 S,SE,SEC,SEL,SD,SDL Class 7 06-08-2006 05:57 AM
500 SEL Normal Operating Temp ricoled W140 S-Class 4 01-22-2006 08:31 AM
Normal Operating Temp? memphise320 W210 E-Class 2 09-15-2004 02:25 PM
Operating Temp Kuzuki G-Class 16 10-02-2003 05:58 AM
Normal Operating Temp ? AZ190E W201 190E, D-Class 4 10-12-2002 04:51 AM
