Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 06-05-2006, 07:10 AM   #1 (permalink)
Date registered: Jun 2006
Vehicle: MB W123 200E 1981
My car vibrates havily when in "Drive", full stop.
Hey,
I have a W123 200E from 1981. I love this car and I will go far to keep it going.
Apart from my motor running at too low rpm (i guess), the car will shake violently when i'm at full stop, with my foot on the brake.
If I switch to "Neutral", the motor will run much more smoothly. no shaking.
I tend to do this now when at red lights, so my teeth won't fall out from all that shaking.
Does anyone know where to attack this problem ?
eggzz is offline   Reply With Quote
Old 06-05-2006, 07:18 AM   #2 (permalink)
smallfence's Avatar
Date registered: Jan 2006
Vehicle: 1981 240D
have you inspected the motor mounts?
20,000mi on biodiesel and counting!
smallfence is offline   Reply With Quote
Old 06-05-2006, 07:22 AM   #3 (permalink)
No not yet but it does feel like it's a change in the way the motor is running
I could be wrong though.
Old 10-12-2006, 07:12 PM   #4 (permalink)
Samoila Stefan's Avatar
Vehicle: Dodge Caravan 3.0 2000 / Mercedes 190E 2.0 1983 / Dacia 1310 TLE 1.4 1990
Send a message via ICQ to Samoila Stefan Send a message via AIM to Samoila Stefan Send a message via MSN to Samoila Stefan Send a message via Yahoo to Samoila Stefan
Mine shakes as well, motor mounts ok, what's the remedy?
Mercedes 190 E 2.0 (1983) 102.961 engine
"In giving advice, seek to help, not please your friend." - Solon (638-559 BC) Greek lawgiver & politician.
Samoila Stefan is offline   Reply With Quote
Old 10-12-2006, 07:47 PM   #5 (permalink)
karugs's Avatar
Date registered: Jan 2004
Vehicle: 83 300D, 90 300TE
Try bumping the idle up.
1983 300D-T 1990 300TE
karugs is offline   Reply With Quote
Old 10-12-2006, 08:05 PM   #6 (permalink)
jdc1244a's Avatar
Date registered: Oct 2004
Send a message via Yahoo to jdc1244a
The thread author may need mounts, as noted above - both he and the guy from Romania need to check for air or vacuum leaks, classic cause of rough idle. Then check the cap/rotor, plugs and wires.
jdc1244a is offline   Reply With Quote
Old 10-12-2006, 10:21 PM   #7 (permalink)
gregdeklerk's Avatar
Date registered: Sep 2004
Vehicle: 74 280SE (A); 84 280E (M); 95 E220 (A)
Are you sure it is a 200 "E"? MB never made a 200 "E" in the 123!! Maybe it is badged wrong?
gregdeklerk is offline   Reply With Quote
Old 10-12-2006, 11:40 PM   #8 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
my car acts the same way....
very high idle when in neutral
obviously runs lean
extremely low idle when in gear (shaking)
this all leads to a vaccum leak, but no matter how much i try, i can't find it! do the vac lines going into the climate servo go to a vac resivoir in the dash? where is it's main sorce of vaccum?
TUNINGGRüPPE.COM
NüR-SPEC is offline   Reply With Quote
Old 10-13-2006, 12:38 PM   #9 (permalink)
karugs's Avatar
obviously runs lean
If it's a similar setup with 190e 2.3's that have shaky idle, the idle control valve may need to be looked at. I just don't know where it is...
Old 10-13-2006, 06:14 PM   #10 (permalink)
jdc1244a's Avatar
The fuel injector seals can leak and cause the rough idle.
