» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-25-2006, 09:01 PM   #1 (permalink)
Date registered: Apr 2006
83' 300D Transmission
My 83' 300D with 169,000 miles up to recently usually would shift from 2nd to 3rd at 3000 RPM. Now it is winding out and shifting between 4,000 and 4,500 RPM. Is this basically an adjustment or modulator valve problem, or signs of a major transmission problem?
Anyone know of a good transmission tech in the NY, NJ area?
kevin300d is offline   Reply With Quote
Old 05-26-2006, 04:35 AM   #2 (permalink)
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
If it's just the 2-3 shift, it could be the K1 spring. Easy fix, really.
Gregs300CD is offline   Reply With Quote
Old 05-26-2006, 05:09 AM   #3 (permalink)
Thanks for the quick reply and the suggestion. The pictures are a big help. This site is best I've found so far for getting practical suggestions and recommendations. I will let you know how things go.
Old 05-26-2006, 08:45 AM   #4 (permalink)
79-300SD's Avatar
Date registered: Jan 2005
Vehicle: 1979 300SD, 1983 300D Mercedes
Send a message via AIM to 79-300SD
Its not that difficult a job...just do it with clean hands. You don't want crud inside the transmission.
Speed is a question of money. How fast do you want to go?
Proud Owner of a
1979 W116 300SD
1983 W123 300D
Come join us at http://schumanautomotive.com/forums
79-300SD is offline   Reply With Quote
Old 05-26-2006, 03:35 PM   #5 (permalink)
Thanks, where can I order the spring kit from?
Old 05-27-2006, 06:13 AM   #6 (permalink)
Gregs300CD's Avatar
Vehicle: 1982 300CD
With the part number (#126 270 44 77), you should be able to order the kit from most places like Fastlane or Schuman automotive. Or, you can stop by the dealer and get a kit for $10-$15. Might want to call ahead if the dealership is out of town, though.
Old 05-27-2006, 06:46 AM   #7 (permalink)
Excellent! Thanks again.
