» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 04-23-2006, 05:49 PM   #1 (permalink)
Date registered: Apr 2006
W123 gas to diesel conversion questions
I have a 1979 280E with a questionable motor, and I would like to swap the motor out for one that I can run on biodiesel. Does anyone know if an engine from a 240D
or 300D would bolt up to the transmission in the 280E? I found someone who will sell me a 240D motor for $200 with all of the wiring, engine mounts, etc. but not the
rest of the drivetrain. If it will bolt up what additional parts would I need? I figure I could use the existing gas tank, as it already has a return line and just clean it out
well and replace the fillter tube. Thanks!
casioqv is offline   Reply With Quote
Old 05-11-2006, 10:59 PM   #2 (permalink)
Gvigorus's Avatar
Date registered: Oct 2004
Interesting thought. The ultimate source would be to ask a mercedes mechanic, they should know everything. I don't know if you have one around, i do so that's where i would go. Check manuals for both cars. You could probably even email the national headquarters. They are really good usually. I asked them once for some cruise control diagrams and they sure enough mailed me a packet with a bunch of print outs (taken from authentic German sources). So, definitely check with someone who does Mercedes professionally.
Gvigorus is offline   Reply With Quote
Old 05-11-2006, 11:26 PM   #3 (permalink)
Boardmonger's Avatar
Date registered: Feb 2005
Vehicle: 83 300d turbo, 79 c123 AMG
How will it pass smog?
-Zack K.
1983 300d Turbo (Daily Driver) -- 243,000 miles
1979 280ce AMG (Sadly sitting, awaiting justice) -- 141,410 miles
1981 300d Euro 4 speed -- 188,421 km -- Sold
1979 300d Euro 4 speed -- 265,000 miles -- Brother's
1995 E300 Diesel -- 49,000 miles -- Dad's
1977 300d -- 148,000 miles -- everyones
A Collection of w123 AMG Cars and Parts
Boardmonger is offline   Reply With Quote
Old 05-11-2006, 11:40 PM   #4 (permalink)
Date registered: Feb 2006
Vehicle: 83 300 d t
Send a message via AIM to washerman
it wont have to you just show dmv the engine i would get dash cluster
plus glow plug relay plus fuel tank plus idler control and the exast is also going to be issue i think tranny the same . please tell me how this turns out .
washerman is offline   Reply With Quote
Old 05-12-2006, 07:34 AM   #5 (permalink)
plurkje's Avatar
Date registered: Oct 2005
Vehicle: 1985 300TD Wagon
Trouble on the horizon!
I've done this, sure it can be done but a differant diesel car wil be cheaper and easier.
You cannot put a gasser tranny behind a diesel engine although it will fit.
You need all the engine wires, from battery and fusebox to steering lock and lamp switch. You need a complete exhaust. The tacho instrument, the differantial...etcetra,etcetra. I am completly sure you will need a million more items, so don't do this unless you have a complete spare car (and then you didn't need to anymore, right?)
plurkje is offline   Reply With Quote
Old 05-12-2006, 02:35 PM   #6 (permalink)
I don't need to pass smog where I live (rual oregon, USA). I've decided that I will try to find a replacement gas engine, sell the car, and use the money to buy a 300D.....
Old 05-13-2006, 06:26 AM   #7 (permalink)
plurkje's Avatar
If it'll be a wagon, it will be better handling the extra weight due to the selfleveling system.
Old 05-18-2006, 06:37 AM   #8 (permalink)
Date registered: Mar 2006
Vehicle: 1991 300TE 4MATIC, 1984 300TDT, 1971 Datsun 510 wagon, 1969 VW Squareback
Fuel tank is the same... but your E has a restrictor in the filler neck that needs to be removed (it prevents someone from sticking a bigger diesel fuel filler in there). You could use the existing fuel tank as long as you clean it well. Eastwood has some great products for cleaning fuel tanks.
Oh, and I agree with everyone else: unless you have a ton of spare time it would be much easier (and most likely cheaper) to buy the car you want instead of building it.
porkchopzz4 is offline   Reply With Quote
