Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 02-07-2006, 11:46 AM   #1 (permalink)
howimademymillions's Avatar
Date registered: Apr 2005
Vehicle: '83 300CD, '82 300TD
F-F-F-Fuel Lines!
Next step for Vanessa to get her vroom back is a full fuel line replacement (off with the crud!)
Was just wondering (before i crawled under the thing to start measuring) if anyone actually had a schematic diagram for the fuel line setup. It'd be great to know the exact bending angles and lengths.
Also what do people recommend for lines? Copper? Steel?
Cheers and thanks fellas!
HIMMM
We've got heads on sticks
And you've got ventriloquists
howimademymillions is offline   Reply With Quote
Old 02-07-2006, 12:18 PM   #2 (permalink)
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
RE: F-F-F-Fuel Lines!
I believe they're steel (because I've heard of people's aged lines putting rust chips into the filter).
Gregs300CD is offline   Reply With Quote
Old 02-07-2006, 01:31 PM   #3 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
do a search under my name for
hard line replacement
Jake
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1168796&posts=13
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1167434&posts=4
BF_JC230 is offline   Reply With Quote
Old 02-07-2006, 02:22 PM   #4 (permalink)
Oh I know mine are steel ;)...wondering what the best replacement...steel=rust, copper might be too soft?
On those links right now..thanks!
-HIMMM
Old 02-07-2006, 02:29 PM   #5 (permalink)
Oooo looks like fun Jake!
I wasn't sure how much had to be removed to access those buggers.
You used stainless steel...did you bend your own? How much/what thickness line will it need?
I'll let you fellas know how I make out ;)
-HIMMM
Old 02-07-2006, 03:01 PM   #6 (permalink)
BF_JC230's Avatar
no - i did not use stainless - i had it quoted from a local place here in WNY - that is in all the Mustang and HotRod mags....but the OEM ones were a lot cheaper - and when my dad and i thought about it...the OEM ones lasted 22 years or so - in Buffalo winters - SALT - with no fatal or any real problems...(although they looked very very close to failure-and in a few spots crumbled upon removal!!!) and now that my w123 is a summer only car - we figured the steel ones would be good again-and before and after install i used a heavy clear coat on them to try and lock out moisture - esp...up around and above the rear subframe...shoot - i dont even drive her in bad weather....
i used Goodridge flex lines - in stainless, rebuilt all the calipers, and have drilled rotors...
when they go - the w126 upgrade is going to happen!
Jake
